Author Topic: 428 help please  (Read 23111 times)
aarons428
428 help please
« on: December 24, 2011, 04:44:02 PM »
I have had my 428 for quite a number of years now but i REALLY don't know much about how to make them really run. He is a run down on what i have so far.
66 428 4v out of a 66 2door LTD(now deceased)
rebuilt in 1996
30 over bore
10/10 crank
stock compression 10.5
out of the box Edy heads
streetmaster single plane intake (previously modified not by me)
Holley 850 double pumper
crower cam 16255
280/288 duration
549/550 lift
108 centerline
duration @.050 224/232
last but not least 125 shot of nitrous
hooker supercomp headers
I am pulling the motor out and I'm going to tear it down to inspect for any wear. i have never had the oil pan off this motor since it was rebuilt in 96. the mods have come over time since the rebuild. This is mainly a good day beat around truck that goes to the drag strip a few times a year. I really have no "problems" with the motor other than a little noise at steady throttle. Nitrous has only been on the motor for 3 years.
What mods should i do to the oiling system when i have it apart if any. it already has a high volume pump on it. oil pressure is about 75ish when cold and 20plus when hot.
I would like to make a little more NA power. I am on a small budget. what would help me the most cam, higher compression, different carb????? I don't want to turn this motor over 6000rpms.
This motor is in a 65 f-100 swb that weighs about 3450lbs.
ANY info will be great. please feel free to ask any questions you may have on this. Don't bash me to hard I'm still learning. THANKS FOR YOUR HELP.
« Last Edit: December 24, 2011, 05:41:33 PM by aarons428 »
65 f-100 swb
428 4v
c-6 trans wide ratio
3000 stall converter
torino front stub
latter bar style rear suspension w/air bags
11.96@110mph
rcodecj
Re: 428 help please
« Reply #1 on: December 24, 2011, 05:03:17 PM »
What rearend gears?
What transmission?
What rpm converter if automatic?
What ET withough nitrous?
aarons428
Re: 428 help please
« Reply #2 on: December 24, 2011, 05:28:38 PM »
9in ford 4.10 mini spool
315/60-15 mickey thompson ET Streets
c-6 trans 3000 stall wide ratio gear set(4r100)
the last time i ran just the motor it was 13.78@105 and 12.45@108 on the bottle
since then i rejetted and ran 11.96@110 on the bottle
didnt get to make a run on just the motor
65 f-100 swb
428 4v
torino front stub
11.96@110mph
rcodecj
Re: 428 help please
« Reply #3 on: December 24, 2011, 06:19:25 PM »
Something seems amiss on the qtr mile times off the bottle.
The mph should have gotten you into the 12's naturally aspriated.
Was traction a problem on the 13.78 at 105 run?
Do you remember what you shifted at?
My analyzer has you hitting 5360 at the end of the qtr mile, does that sound about right?
29.9" tall tires, 4.11 gears and 105 mph is around 4800, but I guess DRA add converter slippage rpm.
Sorry for all the questions, but it will make it easier for people to suggest appropriate parts such as cams.
aarons428
Re: 428 help please
« Reply #4 on: December 24, 2011, 07:05:06 PM »
no problem with questions
I went and got my time slips
pretune on nitrous
60ft 1.6673
1/8 et 7.8067
1000et 10.2383
1/4 et 12.45
1/4 mph 104.85
pretune on motor
60 ft 1.8469
1/8 et 8.6780
1000 et 11.3574
1/4 et 13.7847
1/4 mph 95.74
better tune on nitrous
60 ft 1.631
1/8 et 7.558
1000et 9.936
1/4 et 11.963
1/4 mph 110.87
sorry for the wrong post earlier
for the most part not much of traction issue hooks hard
I shift at about 5800-6000
through the traps at about 5500 crappy tach need new one
65 f-100 swb
428 4v
torino front stub
11.96@110mph
rcodecj
Re: 428 help please
« Reply #5 on: December 24, 2011, 07:42:32 PM »
For oiling mods I would make sure you have an oil pan with baffles and extra oil capacity.
I would run the larger oil pump drive.
I would also enlarge and smooth the oil pump passage where the oil pump bolts on. I don't recall the size, maybe someone will chime in.
On the block after pulling the heads I would check the deck height. If the pistons are down in the hole I would have it decked to bring them up to the top.
I would measure all four corners to see what you get and go from there.
I'm assuming you've done something with the rockershafts, if not I would add spacers and end stands.
You could have a mild port and clean up done on the Edelbrock heads, might be more than your budget though.
It all depends on what you want to spend.
I think you could go a bigger cam, something around 230ish dur at .050 hydraulic, or 240ish dur at .050 solid.
I'll let others chime in on the camshaft specs.
And as long as you have it apart I would degree the cam, new or old.
Lastly I would highly recommend buying Jay Brown's book and Barry Rabotnick's book.
http://fepower.net/GFEIC.html
http://www.survivalmotorsports.com/
« Last Edit: December 24, 2011, 07:47:40 PM by rcodecj »
Re: 428 help please
« Reply #6 on: December 28, 2011, 06:42:56 AM »
Sounds like a bit of a mismatch between the low duration cam and possible low compression (which work together) and the 850 double pumper and 3000 converter (which work together).  I tend to agree on the idea of decking/checking the pistons deck clearance, along with the cam suggestions as to more intake duration.  And I would probably stress getting a really good valve job and some bowl blending work for the heads - a fair amount to be gained there.
bluef100fe
Re: 428 help please
« Reply #7 on: December 28, 2011, 08:14:09 PM »
First off cool truck.... Are you sure its 3450? My 76 is 3900 with me in it and a full tank. Anyway, I wish my truck was that light. I pretty much agree with everything that's been said already. Get the 428 up to  a true 10.5 to 1 compression ratio if it isn't already, zero deck the block, and mill the heads as necessary to get there. Are you running just pump gas? Get a good valve job done while the heads are at the shop. I'd add 10-15 degrees of @ .050 duration and try to get closer to 0.600 net lift. Good shafts, rockers, and end stands are recommended. Lastly I'd get the converter restalled to at least 4000. Should be able to run bottom twelves or high elevens, and still drive it anywhere. Hope this helps.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
aarons428
Re: 428 help please
« Reply #8 on: December 28, 2011, 09:18:30 PM »
This motor right now doesn't pull very hard past 5500rpms. How hard can i turn a "stock" bottom end? i am up for ANY suggestion for a cam thinking of a solid instead of a hydraulic.
As far as the weight. torino front clip, short wheel base, fuel cell in the back, home made latter bars with airbags on the rear, early bronco 9in housing, It is no more than 3500lbs i weighed it this summer.
I'm not so sure about 4000 stall but i will check with my converter company. I work for a small tranny shop so i get stuff for cost.
Sorry to say but I'm on a small budjet so i think a cam change and decking the block is more along the lines right now. is this along the right lines? I would just love to build the hell out of this but the family comes first.
I'm also working on trying to get two 428 irrigation engines but one has a hole in the block from a rod and the other has a hole in the timing cover from the timing chain coming apart PLUS both have been outside for a few years.
« Last Edit: December 28, 2011, 10:35:52 PM by aarons428 »
65 f-100 swb
428 4v
torino front stub
11.96@110mph
bluef100fe
Re: 428 help please
« Reply #9 on: December 28, 2011, 10:27:51 PM »
Well if you want to go bigger on the cam you have to match the converter to it. Barry touched  on this in his post.... the combo has to be matched for best performance.  For instance I run a converter that stalls to 4200 on the Transbrake with the throttle wide open and no two step. My engine is smaller than yours and has a bigger cam than yours. I still drive it on the street and don't have any problems with heat. If that's what your worried about? I still pull a trailer on occasion with this truck. I think you could use a higher stall converter with your current cam. As far your stock bottom end goes. How stock is it? Its really hard to put a limit on it without knowing exactly whats in it. If its got stock 35 year old rod bolts in it I wouldn't turn it over 5000. If its got arp bolts in it I wouldn't turn it much over 6000. That's just one example of one unknown piece of the puzzle. Hope this helps.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
aarons428
Re: 428 help please
« Reply #10 on: December 29, 2011, 11:35:41 AM »
the bottom end is STOCK the motor was rebuilt in 1996 back to stock specs with no intent on racing. But that all changed a couple years after i had it rebuilt. original everything other than new pistons.
65 f-100 swb
428 4v
torino front stub
11.96@110mph
price5113
Re: 428 help please
« Reply #11 on: December 30, 2011, 11:47:01 AM »
Not to change the subject on this post, but what are you guys doing for the rear suspension set-up's on your trucks? Blue F100FE, your truck flat hauls! Very impressive for the weight you are carrying!
aarons428
Re: 428 help please
« Reply #12 on: December 31, 2011, 09:28:50 AM »
On my truck i have home built a "latter bar" set up with air bags and shocks nothing special.
65 f-100 swb
428 4v
torino front stub
11.96@110mph
price5113
Re: Rear suspension................
« Reply #13 on: January 01, 2012, 02:06:32 PM »
Got any pics of your setup? Sounds like it works well. I'm doing a 71 F100 "STD" bed truck, and kicking around some different ideas on the rear susp. setup..........
bluef100fe
Re: 428 help please
« Reply #14 on: January 03, 2012, 04:20:28 PM »
Im using stock cut leafs and rancho shocks with some home made slapper/ladder bars. 90/10 shocks up front.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
