Author Topic: howards cams  (Read 15793 times)
Grbmaverickmo
howards cams
« on: January 27, 2015, 11:29:19 AM »
I don`t post much but read alot of what is posted on here to learn what I can about the FE. Has anybody tried the New Howards Rattler cams. I know they are trying to compete with the Comp thumper cams which people seem to not like. But the Howards numbers seem pretty decent atleast from what I read works in these FE motors. Thanks
bn69stang
Re: howards cams
« Reply #1 on: January 27, 2015, 04:20:43 PM »
Have nt even heard of anyone using them , IMHO dont really think much of the thumper cams , a choppy solid or a hydr roller sound better .. Bud
Grbmaverickmo
Re: howards cams
« Reply #2 on: January 30, 2015, 10:00:33 AM »
Yeah I hear alot of bad about the Thumper cams. I dont argue about what works and what don`t. I have a story about a Thumper in A very mild roller 302 (it had good heads thats about it) in One of my Mavericks that people would argue up and down it wasn`t true but I had time slips. I would have never ever thought that motor in that car would have worked as good as it did. On junk pep boys radials thru the full exhaust with a 2500 stall and 3.55s. It went 2.0 60fts, 11.70s at 117 all day. It had no low end but when it got past the 60ft it was pretty impressive. Oh the car was 2845 with me in it so it was lite but Mavericks are. I by no way saying Thumpers are good but that one worked well in that combination.
Re: howards cams
« Reply #3 on: January 30, 2015, 11:26:18 AM »
I think when Thumpers first came out we all balked at the huge amount of overlap generated by tight LSA and a sorta too big exhaust lobe.  However, I think since then people have been doing OK with the lobes
That being said, I haven't used one but know they aren't as bad as everyone originally thought
Grbmaverickmo
Re: howards cams
« Reply #4 on: February 10, 2015, 01:50:41 PM »
Well I bit the bullet and bought a Rattler cam from Howards. If it works awesome if not I`ll try another cam next winter. Heres the specs on what I got.adv duration 289/297, dur@.050 235/243, lift is .548/.548 and lobe sep is 109. Needs 9.0;1 comp and 2500 plus stall. We shall see what it does in my 69 390gt motor. I am slowly gathering all the pcs to get it together for the FE race at Beaver.
Re: howards cams
« Reply #5 on: February 10, 2015, 02:40:58 PM »
I don't like the idea of the off-the-shelf Thumpr cams for a driver.  With a 107LSA and 14° intake/exhaust split, I just don't think it would be prudent for someone looking for vacuum or good street manners.  Tons of overlap there.
I think they would work pretty good for a rowdy street motor or a street/strip deal, where the manners didn't manner.
With that being said, I use the individual lobes a lot, in a custom cam where I can pick and choose the intake and exhaust lobes, LSA, etc.  They are not noisy at all and have a nice amount of lift for most aftermarket heads.
KMcCullah
Re: howards cams
« Reply #6 on: February 10, 2015, 05:17:50 PM »
I think that cam will work just fine in a 390. Especially with GT heads. It only has 75 degrees overlap. Should sound good.
Kevin McCullah
900HP
Re: howards cams
« Reply #7 on: February 24, 2015, 05:58:55 PM »
The "rattler" cams are some of the last lobe designs of the late Harold Brookshire, they should work just fine.  That seems to me to be a bit much camshaft for a 390 unless you are intending to turn it some rpm but it will definitely "sound" good.  With decent heads that should be peaking around 6000+ I would think.  If you really want it to run make sure you get the GOOD hi-rpm roller lifters from Morel, they are worth quite a bit of power.
Re: howards cams
« Reply #8 on: February 24, 2015, 09:32:08 PM »
Just for some trivia, the Howard Cams Rattler was the name Howard Johansen gave his AA/FD back in the day... He raced it from the late 60s into the 70s.  It was the Winternationals Top Fuel Eliminator in 1969 among some other major meet wins.  It's a great looking car, especially at speed!
It has been restored and is now a star of the Cacklefest.  http://cacklefest.com/Rattler.shtml
Bruce
