FE Technical Forum
Torqueing the Crankshaft Damper Bolt
Topic: Torqueing the Crankshaft Damper Bolt (Read 5904 times)
rockittsled
Full Member
1976 F-250 390 4v C6
January 27, 2015, 09:03:38 AM »
What do you suggest I use to lock the engine while breaking loose and torqueing the crankshaft damper bolt while the engine is installed in front of a C6? Would a piston stop work or might it damage a cast piston?
Howie
Re: Torqueing the Crankshaft Damper Bolt
Reply #1 on:
January 27, 2015, 09:38:27 AM »
Hit it with an impact gun.
Or take the cover off the converter and wedge the converter.
KMcCullah
Reply #2 on:
January 27, 2015, 11:06:28 AM »
What Howie said. Or if a 1/2 impact isn't available maybe you could borrow one of these from a local Autozone or Oreilly......
http://www.amazon.com/Lisle-23800-Flywheel-Turner/dp/B000FN7JE2/ref=sr_1_2?ie=UTF8&qid=1422374627&sr=8-2&keywords=flywheel+wrench
Kevin McCullah
shady
Reply #3 on:
January 27, 2015, 01:10:30 PM »
in a pinch, I've already used a pipe wrench on the crank spacer behind the balancer to hold the crank from turning, but it will leave a mark.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
chris401
Reply #4 on:
January 28, 2015, 12:57:54 PM »
A chain tong wrapped around pulley works. Cut up a mud flap or tire to protect pulley.
Reply #5 on:
January 28, 2015, 02:47:17 PM »
I've got one of those Lisle flywheel turner/lockers that Kevin linked.
They are the cats meow.
Except I bought mine off a Maatco truck and prolly paid almost twice that.
FE Technical Forum
