Author Topic: 65 f-100 never ending project  (Read 8873 times)
aarons428
« on: December 24, 2011, 04:11:47 PM »
This is my first vehicle i  bought when i turned 16 back in 1994. It started life as a 240 6cyl and 4speed. When i got bored with that i put in a 352 and an automatic. A year later my dads 66 2door LTD got totaled out which happened to have a 4v 428 with a c-6 trans. I wanted more motor and we joined the two together along with a torino front stub and lowering the rear. We had the motor rebuilt to stock specs and trans rebuilt also.
I had a friend introduce me to the world of drag racing. I was hooked and the truck has been a work in progress ever since. The best quarter mile run so far has been 11.96 @110mph.
Motor specs as it sits
30 over bore
10/10 crank
stock compression 10.5
out of the box Edy heads
streetmaster single plane intake (previously modified not by me)
Holley 850 double pumper
crower cam 16255
280/288 duration
549/550 lift
108 centerline
duration @.050 224/232
last but not least 125 shot of nitrous
c-6 trans 3000 stall wide ratio
truck weighs about 3450lbs
« Last Edit: December 24, 2011, 04:50:41 PM by aarons428 »
65 f-100 swb
428 4v
c-6 trans wide ratio
3000 stall converter
torino front stub
latter bar style rear suspension w/air bags
11.96@110mph
Hemi Joel
Re: 65 f-100 never ending project
« Reply #1 on: December 27, 2011, 10:50:57 PM »
That's a neat truck. You've done well to get it into the 11's.
Maybe one of the reasons that I like it is that my 1st vehicle was a 66 f100 with a 240 and a 4 speed.
Good luck with it!
Joel
drdano
« Reply #2 on: December 27, 2011, 11:44:52 PM »
Love those trucks.  My first "car" was a '63 F100 2wd straight off of grandpas farm.  292 and a 3-on-a-tree.
