Author Topic: FE Timing Covers  (Read 64039 times)
FordEver
Re: FE Timing Covers
« Reply #45 on: January 31, 2016, 06:16:01 PM »
Interested in the 14001 timing cover. In stock ? Does the same deal as listed above still apply ? thanks , Bob
« Reply #46 on: January 31, 2016, 09:15:25 PM »
They are in stock, and the pricing shown at the beginning of the thread still applies - Jay
Richard Paul Metzger
« Reply #47 on: February 07, 2016, 12:33:45 PM »
Hi Jay, Any plans for two piece valve covers? Removeable  top! Thanks Richard
« Reply #48 on: February 07, 2016, 01:50:37 PM »
Hi Richard, I don't have any plans to make something like that.  I'm not sure what advantage they would offer; the only thing I could think of would be to run the engine with the tops off, or pre-oil with the tops off, to minimize any mess.  To me, its just as easy to remove the whole valve cover.  Am I missing something?  What would be the advantage of a part like this?
« Reply #49 on: February 07, 2016, 07:40:10 PM »
Hi Jay, Adjusting the valves with the engine running? Thanks, Richard
« Reply #50 on: February 07, 2016, 08:12:13 PM »
Now that would be a neat trick, adjusting shaft mounts rockers while running . lol.
« Last Edit: February 07, 2016, 08:30:19 PM by fekbmax »
« Reply #51 on: February 08, 2016, 12:02:19 PM »
No one adjusts valves with the engine running.....
rant/ That is normally the advice given by the guy that tells you to disconnect the battery while the engine is running to check if the alternator works.  He also is the guy that says to just "crank down" on that there bolt on the steering gear to tighten it up.  This is the FE Power forums.  If you want to get advice like the above, feel free to visit just about any Ford truck forum and I'm sure some 16 year old will tell you to do it that way "because I always done it that way, like my pappy told me ta." /rant
« Reply #52 on: February 08, 2016, 12:47:49 PM »
I've actually seen that done on an FE with hydraulic lifters and adjustable rockers; a backyard mechanic I knew in the 1980s did it that way once when I was watching.  He had one noisy lifter he was trying to quiet down, and used some kind of a loose deep-well socket on the adjuster head and tightened it until the lifter noise went away with the engine running.   Socket and extension were rattling around like mad LOL!  Not a really good plan, of course...
« Reply #53 on: February 08, 2016, 01:13:10 PM »
Ok now I have to talk about my dark side.
I have adjusted BB chev rockers while the engine is running.
They sell these little clips to clip on the rocker to slow the oil squirt
and you crank down on the rocker until the noise stops.
Yes I have been to the dark side. :o
I had a 69 396 Chevelle. I will probably always have a soft spot for it.
« Reply #54 on: February 08, 2016, 01:59:09 PM »
oh well, on a Chevy that is different..... it's probably in the Chevy shop manual.
"To set valves, take a large impact gun with a 7/16th socket.  Set air pressure for 150psi and tighten down on each rocker adjuster until all noise stops."  -1966 Nova Shop manual
FE Jonny
« Reply #55 on: February 09, 2016, 04:38:33 PM »
I'm ready for a 14002 when you are :-).
Jon Heintz
« Reply #56 on: February 09, 2016, 07:27:13 PM »
Sent you a PM, Jon...
FE Jonny
« Reply #57 on: February 12, 2016, 11:45:28 AM »
Got my 14002 today, thanks Jay nice part!
Jon Heintz
FE Jonny
« Reply #58 on: February 12, 2016, 12:21:10 PM »
Quick stupid question after reading the instructions, I have one of Barry's spacers that is shortened to accept the ATI balancer. Do I still need to machine the spacer? I do not have in front of me but as I remember it is smooth all the way. It was shortened 7/16 to make the balancer line up in the original location.
Jon Heintz
« Reply #59 on: February 12, 2016, 01:04:02 PM »
Jon, the sealing surface of the crank sleeve has to be lengthened along the sleeve if you use the 351C front seal that installs from the front.  Otherwise, the seal will not ride on the machined surface of the sleeve.  No machining of the crank sleeve is necessary if you use the FE front seal that installs from the back - Jay
