FE Technical Forum
Oil for flat tappet
Topic: Oil for flat tappet (Read 7297 times)
JimNolan
Sr. Member
63 Galaxie XL 410ci / 57 Fairlane 500 390ci
Oil for flat tappet
January 15, 2015, 07:50:06 PM »
I have been running Brad Penn 10W-30 in my cars and they went way up in price. So, I bought a case of VR1 30W that has about the same pour qualities of the Brad Penn and about the same Zinc content. Does anyone else run this oil and would you share your experience good or bad. Thanks, Jim
Re: Oil for flat tappet
Reply #1 on:
January 16, 2015, 07:54:23 AM »
I think you're in pretty good hands with that oil. After the cam is broken in, the drama is pretty much over, but I always recommend that my customers run the Brad Penn break-in oil or the VR1 non-synthetic race oil after they receive the engine. Brad Penn is certainly expensive.
BTW, you have to watch about some of the Brad Penn oils. Some of them are partly synthetic, and I just don't have a good feeling about using synthetics in a fresh engine.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
blowrsnob
Newbie
Reply #2 on:
January 16, 2015, 01:55:28 PM »
Coincidentally; article from Engine Builder Mag published today.
http://www.enginebuildermag.com/2015/01/picking-racing-oil/
manofmerc
Sr. Member
Reply #3 on:
January 20, 2015, 05:22:59 AM »
Jim I have had good luck with Valvoline vr1 .My 460 powered 67 comet has a solid flat tappet camshaft as well as my 427 66comet.The 460 has 380-385 lbs.open spring pressure and the 427 has just a bit less .My cam and lifters look great whenever I do maintenance to the engine I have 10-30 in the 427 and 20-50 in the 460 .I have been looking at Lucas products recently they also offer several different weights of oil for flat tappet engines .They have a 15-30 truck engine oil that isn't to expensive it has the zddp additive but I just keep running VR1 it has worked for me .Doug
Reply #4 on:
January 24, 2015, 03:17:43 PM »
I've run VR1 in both 10W30 (winter) and 20W50 (summer) or a mix of the two with no problems. I've used both the regular and the synthetic types. This is on a solid flat tappet cam with over 400 lbs of open pressure. I also use Mobil 1 15W50 in the 5 quart jug from Wal Mart. You can sometimes get this for less than $20. More often it's around $25.
paulie
bn69stang
Reply #5 on:
January 27, 2015, 07:47:31 PM »
I use 10 w 40 semi blend , and a bottle of the additive zddp in my 28 and so far so good .. Bud
69 mach 1 , 428 C J Blue Oval Performance BBM heads -T@D rocker s- Blue thunder intake - Comp hydr roller - MSD ignition - FPA headers- Holley 850 hp double pumper - TKO 600 - 9 inch 3.89 Detroit Locker . ride tech coil over conversion - power rack @ pinoin steering - 13 inch drilled @ slotted 4 wheel disc brakes ..
Reply #6 on:
January 29, 2015, 03:15:50 AM »
The last 2 FEs in my Fairmont (1 428, 1 427), as well as the 331 SBF in my 85 Mustang, all have solid flat tappet cams, & I have used Brad Penn 10-30 in all 3, with no wear issues. I see no reason to change.
FE Technical Forum
Oil for flat tappet
