Author Topic: Fel-Pro 90145 intake gasket  (Read 5820 times)
rcodecj
« on: December 15, 2011, 04:20:49 PM »
Is the Fel-Pro QMS90145 intake gasket ok for PI intake and Edelbrock heads?
Here's a link:
http://www.summitracing.com/parts/FEL-MS90145/
Re: Fel-Pro 90145 intake gasket
« Reply #1 on: December 15, 2011, 06:18:46 PM »
Yes it can be used.
I kinda like them. They are a good long haul gasket.
Can't really say how they line up on a PI, but should be ok.
I never use end seals on the intake to bulkhead ends. Only silicone on the ends and a smear around the water ports.
Make sure you snug the intake down good after the first heat cycle.
rcodecj
« Reply #2 on: December 15, 2011, 06:43:28 PM »
If I recall correctly, the PI intake matches the top and is shorter on the bottom. The sides I don't remember.
