Author Topic: July 1979 Hot Rod PSE article  (Read 8511 times)
KMcCullah
« on: December 08, 2014, 09:17:31 PM »
Since dad's retirement he's had a lot of time on his hands. He's been methodically reading through his entire Hot Rod magazine collection that spans several decades. While visiting this weekend he showed me an interesting article on Paul Bedoian and PSE. The best of his FE innovations are the ones that Jay has improved on and reproduced. Some of his FE parts just seem a little too much like snake oil. Aluminum main caps, REALLY??? And several other things seem like half baked ideas to me. Fixing things that we don't have problems with and such. Several of his engine building techniques made me chuckle also. Enjoy guys.
Kevin McCullah
Re: July 1979 Hot Rod PSE article
« Reply #1 on: December 08, 2014, 11:17:31 PM »
I remember that article!  One reason is the magazine cover; the Willys was built and owned by a local friend of mine, Gary Kollofski.  Really a cool car.  The other reason is, as you mentioned, some of the strange assembly techniques.  Finishing the  bores mirror smooth??  Hmmmm....
Thanks for posting that, Kevin, its a blast from the past alright!
wayne
« Reply #2 on: December 10, 2014, 05:48:48 AM »
I found that i have bent the cranks in all the engines i have built but most have stayed together.Never thought they were that weak must be how cross bolt mains help.
« Reply #3 on: December 10, 2014, 08:46:52 AM »
I also remember that article when 1st published. Paul had some good stuff for sure but some crazy ideas too.
-the cross-bolt side oiler system may have made sense for blown fuel SOHC's yet they survived w/o it for years. Also, the era of blown fuel Ford dragsters and F/C's from the late 60's to early 70's well pre-dated his late 70's invention so it made even less sense when it appeared in this 1979 article.
-the super smooth cylinder walls  did make sense, in a fashion. Today's Pro-Stock builders use a graduated fish scale to pull a piston and ring stack though each bore long before final assembly to check for extremely low drag. Yet to do so way back then on much lesser engines didn't make any sense since what works for a Pro Engine often doesn't work for a much higher mileage streeter or even dedicated Stock or SS car. Blowby is your friend, I guess  ;)
-The ring gap theory also doesn't hold water. He was o.k. until he stated that even .070 gaps were fine. Heck, even on the blown fuel engines we crewed on in the late 70's, .050 ring gaps were way too big but was run on bores that had been torched and no spare pistons with properly sized rings were available. This was just before removable liners came about as Donovan's aluminum  417 block, a 392 replica, had them 1st. Funny though it didn't make much difference as with .010 and larger bore clearances, way too- big ring gaps and 98% in the tank, the engine was eventually going to blow no matter what!
-his header comments were off as well since although gains might have been small, some header designs and sizes properly  matched to the engine did make a difference even way back then. SS racers then were experimenting with various designs, some successful, some not. To be fair, I suspect since PSE didn't make headers, all were the same to Paul.
JMO!
« Last Edit: December 10, 2014, 08:59:42 AM by machoneman »
Qikbbstang
« Reply #4 on: December 10, 2014, 08:57:53 AM »
The rumors of just how Pro Stock Paul was able to offer such exotic FE hardware are as wild as the scope of all Paul's FE hardware itself. Jay offering up a modern CNC'd version of the FE intake adaptor was an impressive accomplishment today, but way back then the version Paul sold was likely the first ever brought to production.  Ditto his alum dampers, windage tray baffeling, alum blocks, clear rocker covers, rocker support system, via main cap lube kit, dual feed oil pumps. rocker support systems etc.. I kind of recall Paul even offering pneumatic valve springs and aluminum cranks?
fairlanegt427
« Reply #5 on: December 21, 2014, 10:27:04 AM »
that is just a really neat article.  mr beaudoin at the time I feel was way ahead of the curve on fe engine performance and technology.  one thing I do agree with jay on is the smooth bore.  I would love to see one of our engine builders try the smooth bore and do a dyno run.   also as pauls article  said he didn't run these on a dyno,  didn't like the dyno numbers as opposed to engine being in car and running and moving.  I have a friend that does this procedure also. he will run motor on engine stand break in cam, check  for leaks (these are fe motors) then put in car. they sound really good until their in car, then I ride in car and am not impressed.  I moved away from him building me my fe's and have been very happy with barry at survival.  point being spend a little on your engine combo and have someone build it that knows what their doing.  my thought is you have 10k in your rebuild so whats another 3k to pay for labor. I know money doesn't grow on trees but in the near term that little extra investment pays for itself big time.
« Reply #6 on: December 24, 2014, 03:38:33 PM »
Reading that article is what made me go to visit him about a year later. Time has proven him right about a lot of things. Keep in mind back then the headers were not offered in shorty styles so tube diameter was about the biggest variable.
 Those 7/16 to 3/8" tapered pushrods are pretty trick!
