Author Topic: 1962 vs. 1966 390 FE  (Read 5328 times)
Nelybel66
« on: December 04, 2014, 09:59:59 PM »
Hi All!
Without going into all the gory details, it appears that my original 1966 390 FE block (from a Galaxie) has been ruined by poor machine shop work.  I have access to a 1962 390 FE block (from a Thunderbird)....and I was wondering if there are any major differences between a block from a 1966 390 and a 1962 390.  Thanks!
Re: 1962 vs. 1966 390 FE
« Reply #1 on: December 04, 2014, 10:45:38 PM »
I think the major differences will be the earlier '62 block will only be the 2 bolt motor mounts so be sure your mounts will work with that or can be adapted. Also the '62 used a cam with a thrust button, you should change that to the '63 & later thrust plate which just involves drilling and tapping the block for the 2 bolts. Also I don't know if the early blocks have the boss on the front for the alternator mount, take a look at that. I believe there was a slight change in the length of the head bolts, but not sure of when that changed. Early bolts were a tiny bit shorter, so be sure if you use the later bolts they don't bottom out in the block. There was also a difference in the thrust bearing on the mains around that time. I believe you need either a bearing set for the early block or to machine where the thrust bearing goes to use the later bearings. All I can think of right now, maybe someone can add if I missed anything.
« Last Edit: December 04, 2014, 10:48:48 PM by thatdarncat »
bsprowl
    • Ford FE Information
« Reply #2 on: December 04, 2014, 10:49:50 PM »
Isn't the thrust bearing different?  Seems to me I ran into that problem once years ago.
Bob
« Reply #3 on: December 04, 2014, 10:52:05 PM »
Yeah, Bob caught me, that was my edit.
Nelybel66
« Reply #4 on: December 05, 2014, 05:50:58 AM »
Thanks for the great reply!!
