Author Topic: Everyday FE and Galaxie parts cheap  (Read 6946 times)
babybolt
« on: November 25, 2014, 08:57:38 AM »
Cleaning out some stuff, good prices on common parts.  The more you buy the cheaper, just want the parts to go.  Actual postage prices, no paypal though.
(2) takeout neutral safety switch, ? late 50's, early 60's F100  $7
(3) 2 arm rests, 64 Galaxie, selling for stainless inserts  $7
(5) 1 gas pedal, has crack in rubber near bottom  $5
(7) 1 early damper, blasted and painted      $7
(7a) heat shield, some original paint, some resprayed, very small pits in some areas, small dent at top $42
(9) high pressure oil pump  $4
(10) stock pump $4
(11) head bolts, best ones selected and tumbled, should be run through a die before use  $15
(14) stock oil pickup, some rust $3
http://s134.photobucket.com/user/stuffnpics/library/fepartsmore
Adding these on 12/3/14, pictures posted on same link as above
361 FT full length pan with pickup and pump, good condition but there is a dent in the pan  $50
Updated on 4/5/15
« Last Edit: April 05, 2015, 11:34:58 AM by babybolt »
69Chop1
Re: Everyday FE and Galaxie parts cheap
« Reply #1 on: November 28, 2014, 04:24:58 PM »
Interested in some of your parts but can't get past the security code to send you a message, either bad eyes or my hearing is gone. You can contact me at
v159hill at rconnect dot com and I will respond that way.
Sorry for the workaround.
Thank you,
69Chop1
abyars
« Reply #2 on: December 02, 2014, 11:54:47 AM »
I'm interested in the rocker arms and push rods.  I sent you a PM.  My email is abyars1955 at gmail dot com
Anthony Byars
1970 Ford F250 Crew Cab 390 C6
1955 Chevrolet 4 door sedan
2004 Ford Expedition
babybolt
« Reply #3 on: December 22, 2014, 08:19:41 PM »
Updated on 12/22, lowered the prices - just want this stuff to go to a good home.  Cheapest shipping is by Priority flat rate box.
« Reply #4 on: December 22, 2014, 08:54:35 PM »
The unknown armrests is 64 Galaxie
babybolt
« Reply #5 on: January 15, 2015, 05:48:54 PM »
Updated 1/15/15, thanks Heo.
Note: scrapped all the pistons, even the ones with the new rings.   Cranks and new camshaft are gone to a guy who builds furniture and trophies with old car parts.
Updated 4/5/15
If you buy the pan, it can be filled with a bunch of stuff, but would have to go Fedex ground.  Make an offer?
« Last Edit: April 05, 2015, 06:47:11 PM by babybolt »
