Author Topic: Oil pan for chassis car?  (Read 6308 times)
falcon428
« on: November 12, 2014, 08:32:37 PM »
What oil pan would you guys recommend for a chassis car?  No crossmember at pan area to worry about a front or rear sump.  Who makes a nice pan?  Ground clearance may come into play as the car will be fairly low to the ground.
Thanks!!
Rodney
'65 Mercury Comet w/ Pond Alum. 427, C6
'61 Ford Starliner w/ 352, C6
'68 Falcon w/ ProCharged FE, Lenco 5sp
'67 Country Sedan SW
'62 Falcon awaiting turbocoupe motor & tranny
'40 Ford Tudor Sedan all original
fe66comet
Re: Oil pan for chassis car?
« Reply #1 on: November 12, 2014, 09:35:15 PM »
I have a Moroso kick out pan with a diamond stripper, it is made out of some tuff steel and fits nice. I like the low profile and addition of extra threaded bosses for plumbing and external dipstick is nice too.mine is a 8 quart front sump which leaves lots of room for a starter and headers, that might be something you might have to think about in a Falcon being a small car???
« Reply #2 on: November 13, 2014, 09:42:32 AM »
If I didn't have to contend with a crossmember I'd be looking at using an AC Cobra type pan. No sump, so you can use a rear pick up which would be a much better choice on anything that will pull some Gs. Plus they work well with low vehicles, which the Cobra obviously is. Space may be a consideration though, as Jon said.
lovehamr
« Reply #3 on: November 19, 2014, 09:01:11 AM »
Rod, this is what I'm running in my BDR cobra.
Good clearance, lots of capacity and great oil control.  Comes with the windage tray and pickup.
http://aviaid.com/shopsite_sc/store/html/ws_oilpns_bbf.html
falcon428
« Reply #4 on: November 23, 2014, 09:16:40 PM »
I have looked at that pan. Thanks.
I am leaning towards building one to fit.
