Author Topic: 6AL box, where did you mount yours?  (Read 20582 times)
amdscooter
« on: November 11, 2014, 10:17:18 PM »
So I finally broke down and got the 6AL (6425) box to mate up to my MSD 8595 Dizzy and Blaster3 coil in my 67 Fairlane 390. Most Mustangs and Fairlanes I have seen these installed in seem to be putting the box on the drivers side tacked to the front face of the shock tower, or in that area. Plenty of space there for sure, any downside such as cable length issues? I'm not planning on moving the coil from the top of the intake manifold at this time.
Thx in advance
-scoot
Re: 6AL box, where did you mount yours?
« Reply #1 on: November 11, 2014, 10:52:25 PM »
That's a good place to mount it, for sure, but on my Mustang I wanted a cleaner factory type look. So I mounted mine inside the car, directly to the bottom of the heater core box, upside down. It doesn't intrude on passenger leg room, I can run the wires out the AC/heater firewall grommet so I didn't have to drill any holes, and the stock MSD wires were just long enough to reach the coil and distributor. Worked out pretty well for me, looks clean and no issues with it getting hot since it's cooler inside than the engine compartment. Plus the fresh air vent is right there to blow cooler air over it on hotter days.
westcoastgalaxie
« Reply #2 on: November 11, 2014, 11:56:52 PM »
Some may frown upon this but I mounted mine behind the air cleaner on the firewall. Been there 10 years now no issues. This is a 62 galaxie.
« Reply #3 on: November 12, 2014, 07:32:30 AM »
Mine is on the passenger side inner fender where my battery used to be.  It's worked fine there for the last 10 years or so.
paulie
Lenz
« Reply #4 on: November 12, 2014, 07:54:56 AM »
Passenger side inner fender near the top for me, '64 Galaxie.  Plenty of wire to get everything hooked up with clean routing.  I'd think you'd be able to mount yours almost anywhere on the 'Lane without running into wire length issues.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
KMcCullah
« Reply #5 on: November 12, 2014, 08:55:52 AM »
MSD claims the 6AL is designed to tolerate under hood temps. And I know a lot of guys that have had no longevity issues with theirs under the hood. But my way of thinking was to keep it cool and really safe. So I put mine in the cab on the firewall. Close to the shifter. It looks good there. And makes people ask
"what's that whirring sound".  ::)
Kevin McCullah
« Reply #6 on: November 12, 2014, 09:45:53 AM »
One problem with mounting an MSD under the hood is that they are susceptible to failure when exposed to too much water.  I lost one once at the car wash; sprayed the water through grille to try to clean all the bugs off, hit the MSD (mounted on the inner fenderwell of my Mach 1), and got nothing when I tried to start the car.  Sent it back to MSD and they fixed it for a small charge, but I've been mounting them inside the car ever since.
wayne
« Reply #7 on: November 12, 2014, 10:09:54 AM »
Mine is on the firewall behind the air cleaner ok for last 10 years
Lenz
« Reply #8 on: November 12, 2014, 11:32:58 AM »
That's useful information right there.  I never would have considered water sprayed in the general direction of the box as being a threat.  Looking at it now I can see where a person could become very unlucky that way.....
Len Zielinski
'69 F100 300 stick
amdscooter
« Reply #9 on: November 12, 2014, 01:58:59 PM »
Thank you for all the feedback. I don't think I need it in the passenger compartment at this point. I'm thinking that spot on the shock tower by the washer bag is looking pretty good at this point. Did you guys with fender mounted boxes run the wiring harness to the dizzy and coil around the engine bay and come in from the firewall like the rest of the OEM harness? Or did you just jump it across from the fender?
65er
« Reply #10 on: November 12, 2014, 02:41:55 PM »
I have mine mounted inside the fender right behind the driver side headlights. Ran the wires directly to the distributor and coil.  But I'm about to relocate it to the trunk, near the battery.
-Wade
« Reply #11 on: November 12, 2014, 04:58:14 PM »
MSD 6 here in a '70 Stang. With my battery in the trunk, the spot where the OEM battery sat is where the box is. Its mounted to a plate and the plate is drilled to bolt to the OEM battery tray holes. The wires run across the shock-tower-to-shock tower brace directly to the coil and ditzy. Works for me!
bn69stang
« Reply #12 on: November 12, 2014, 04:58:27 PM »
I have mine mounted on the drivers side inner fender in front of the shock tower , with the coil underneath the box . But i will keep the water info in mind for sure .. Bud
Lenz
« Reply #13 on: November 12, 2014, 06:28:55 PM »
Dizzy wires run to the firewall and back up in the factory location with the temp sender wire. Ran the coil wires along side alternator wiring and then over in a loom along with the ground lead.  Now that I think about it, the ground was way too short to go back toward the firewall and I wanted a solid hook at the block, so the jump with the alternator wiring made sense.
Len Zielinski
'69 F100 300 stick
amdscooter
« Reply #14 on: November 12, 2014, 08:58:29 PM »
^^^ Thanks! I ended up mounting the box on the inner driver side fender right next to the washer bag instead of the shock tower. The wires for the dizzy and coil look long enough to go around the engine compartment and follow the OEM harness. The two battery leads are a bit short to go across the front clip in front of the radiator and will need to be lengthened. I wanted to get it wrapped up today as I am home sick, but the cold kicked my arse and afer I got the box mounted I wrapped it up. The rest of the week is booked with work catch up stuff. Hopefully I'll get it wrapped up this weekend. I'l post up a few photos when it's complete. thanks for all your input!
