Author Topic: gaskets  (Read 5263 times)
abyars
gaskets
« on: October 28, 2014, 11:30:26 AM »
What gaskets do you guys recommend for tin valve covers on a 1970 390?  I need to change mine.  I guess it's a typical installation, glue gasket to cover then install?
Anthony Byars
1970 Ford F250 Crew Cab 390 C6
1955 Chevrolet 4 door sedan
2004 Ford Expedition
Re: gaskets
« Reply #1 on: October 28, 2014, 12:27:50 PM »
I use cork and RTV Ultra black.
I also like to put them chev spreader bars on the bottom bolts. You need to drill out the hole
for the 5/16 bolt though.
abyars
Re: gaskets
« Reply #2 on: October 28, 2014, 12:41:40 PM »
Thanks.
I considered those Chevy bars.  I have some from another project.
Anthony Byars
mlcraven
Re: gaskets
« Reply #3 on: October 28, 2014, 05:31:55 PM »
X2 on cork and the Chev spreader bars (learn something every day -- never knew that's what they're called).  Although it likely makes no difference whatsoever, I also use them on the top middle bolt as well.  Regardless, no leaks.
Michael
Re: gaskets
« Reply #4 on: October 29, 2014, 09:22:50 PM »
Use the Pontiac spreader bars which already have 5/16" holes.
