Author Topic: Shout out to Jay Brown.  (Read 4433 times)
dsrtjeeper
« on: October 22, 2014, 08:26:34 PM »
Hi Jay. I'm looking to install Edelbrock heads on my 390. The catch is that the engine is in a '66 F100 and I need to use truck headers for the lower port C8 heads. I saw this pic in your article in Car Craft:
http://www.carcraft.com/techarticles/ccrp_0808_ford_390_fe/photo_17.html
Those truck headers look like my Flowtechs.
Maybe this can work and what header gaskets did you use?
Thanks!
Eric
Re: Shout out to Jay Brown.
« Reply #1 on: October 22, 2014, 08:50:07 PM »
That should work for you.  If I recall correctly on the gaskets, I used a set of gaskets for a 428CJ.  If your Ed heads are drilled for the CJ exhaust bolt pattern, you could also drill two more holes around each port and use all the bolts, if you wanted...
dsrtjeeper
« Reply #2 on: October 23, 2014, 02:47:02 PM »
Thanks Jay!
