Author Topic: SOLD!  (Read 4939 times)
Hemi Joel
SOLD!
« on: October 20, 2014, 04:44:02 PM »
ROMAC Ultralight Dampeners should be used in combinations where quicker engine response, or extremely high rpm is required.
ROMAC Ultralight Dampeners are manufactured with an Brutal Duty Elastomer band offering increased reaction to the extreme torsional loads created in today's high output racing engines. This design is infinitely superior to clutch or fluid designs that are designed to handle harmonics instead of the twisting of the crankshaft when the full weight of your car lands on the crankshaft.
ROMAC  Ultralight Dampeners with a CNC machined steel hub and an aluminum outer ring. They are the safest dampener offered, as the external balance weights are integral to the steel hub, making it absolutely impossible for the weights to come off the dampener. The aluminum outer ring overlaps the hub and is retained by a .125 thick retainer ring, completing the best engine dampener currently available.
ROMAC Ultralight Dampeners are dimensionally correct for ease of installation, guaranteeing minimal hassle in aligning pulleys and drive belts.  Also the outer ring has 360ยบ timing marks for your convenience.
ROMAC Ultralight Dampeners are SFI approved.
This part is new in the box, in new condition. The box shows shelf wear. You can buy one for $349.99 here: http://www.petersperformance.com/products/124.htm  OR you can buy this one for $225, including free shipping in the USA. I will accept Cash, Paypal, good check or money order. A check would need to clear before I ship. Please respond via email at hemi67gtx@yahoo.com Please be sure to use my name, Joel, in the email to get past my spam filter.
You can check my feedback here: http://fepower.net/simplemachinesforum/index.php?topic=1787.0
« Last Edit: October 22, 2014, 12:56:44 PM by Hemi Joel »
Hemi Joel
Sold!
« Reply #1 on: October 22, 2014, 12:56:03 PM »
Thanks to all who emailed me, and thanks for the free ad!
