Author Topic: 68 Plymouth: Crankshaft Pulley Vibration  (Read 3401 times)
chris401
« on: October 17, 2014, 08:27:14 PM »
I have not isolated belts from pulley or pulley from ballancer yet. Fury II 318 w/ac has the stamped two groove pulley, built in is a rubber isolated cast iron pulley for the ac. Pulley was rebuilt, had first run today. It has a moderate vibration at idle and smooths out around 1500rpm. Anyone know of or had similar problems with the house brand V-belts?
« Last Edit: October 17, 2014, 08:49:19 PM by chris401 »
chris401
Re: 68 Plymouth: Crankshaft Pulley Vibration
« Reply #1 on: October 21, 2014, 12:31:17 AM »
Belts were not perfectly cemetric but they were not the problem. Checked crank in three spots and it was within .00005 +/-. Found pulley/rubber to be out of round causing the belt vibration. Rebuilder said these pulleys are difficult to spin but he would rework it. This time I am sending harmonic ballancer with it.
« Last Edit: October 21, 2014, 02:28:00 AM by chris401 »
