Author Topic: 63 Galaxie heater project  (Read 5691 times)
« on: October 04, 2014, 04:29:36 PM »
Re: 63 Galaxie heater project
« Reply #1 on: October 23, 2014, 07:20:53 AM »
I do wonder if its wise to add a flow restrictor in the top heater hose like the Fox Mustangs have. One can easily make a restrictor rather than buy one. I mention this mainly for those who add a high winding engine (FE or otherwise) and later pop the heater core due to high RPM's causing a massive spike in coolant pressure. I had to replace the core in my genie '88 5.0 Stang a few years ago and man, what a bitch to get to it and not dump the A/C lines. I had done my '63 Galaxie's core long ago and it was much easier but still, prevention may be of help.
http://www.latemodelrestoration.com/item/LRS-18599A/79-04-Mustang-Heater-Core-Flow-Restrictor
« Last Edit: October 23, 2014, 07:23:12 AM by machoneman »
« Reply #2 on: October 24, 2014, 09:50:18 AM »
I'm lazy/cheap Bob, I just buy a heater hose valve that I can open and close.  Due to it being a gate valve, I typically leave it mostly shut....  ie 5 turns to close, I keep it 4 or so, or as experimentation dictates.
Of course if you have a bypass installed (from the intake to the waterpump) it's kinda a moot point.
