Author Topic: Best place to buy custom driveshaft for my 66 482 Truck project  (Read 13369 times)
TimeWarpF100
« on: September 06, 2014, 05:22:50 PM »
I need to order a driveshaft for my '66 F100 482
Who do the members here use?
Thinking on a aluminum one
afret
Re: Best place to buy custom driveshaft for my 66 482 Truck project
« Reply #2 on: September 06, 2014, 06:31:21 PM »
I used inland empire
4inch aluminum, 1350 yokes, etc.
Freakin love it.  Nice folks there too, i told them what I needed, they had helpful suggestions, etc.
troublemaker427
« Reply #3 on: September 06, 2014, 08:46:10 PM »
Dynotech is in all of our cars.  Good price too...
chilly460
« Reply #4 on: September 08, 2014, 09:53:57 AM »
http://shaftmasters.com/
Much cheaper than others, use Alcoa aluminum and Spicer yokes so they don't cheap out on materials.  Mine arrived in under two weeks from time of ordering.
« Reply #5 on: September 08, 2014, 12:26:51 PM »
Where are you located?  That would determine my answer.  Joe-JDC
TimeWarpF100
« Reply #6 on: September 08, 2014, 01:30:10 PM »
Thanks to all for reply's so far.
I am in Phoenix AZ Metro area, far north side
« Reply #7 on: September 08, 2014, 01:43:42 PM »
Dynatech here too
Local to me here
fe66comet
« Reply #8 on: September 08, 2014, 04:11:16 PM »
On the aluminum shafts, how much hp is supported? It appears there are 3",3.5" and 4" in diameter. I wonder at what point a 4130 steel shaft becomes necessary.
TimeWarpF100
« Reply #9 on: September 08, 2014, 04:29:35 PM »
I have made some calls to different places suggested.
I was told at my HP level a 3" chromemoly would be fine
If I went to a aluminum it would need to be a 3.5". the weight savings to 3.5 Alum from 3" steel would be approx 20%
I did not ask at what level the Steel would need to be used. By the sounds of it the larger aluminum will hold a lot of HP. Way over and above of what my 482 will produce.
I was also told I should step up to a 1350 pinion yoke.
TimeWarpF100
« Reply #10 on: September 08, 2014, 04:37:55 PM »
DynoTech was closed when I called or at least no answer.
So far:
Inland Empire is 324.00 for a 3" Steel & 415.00 for a 3.5 ALum
That is using my 1350 trans yoke
MW quoted  429.00 for the 3" chromoly & 559.00 for the 3.5" Aluminum
Both for estimated length of 49"
When I started this build I re-used my stock 28 spline axles and yoke in the 9"
I did add a Yukon posi
So looks like the next week link will be the center section.
MW quoted me 606.00 for a pair of axles and 1890.00 for a "N" case unit complete.
I flat out do not have the $$ for either.
Once I am doing the driveshaft I have to make sure it will hold the power and then plan on doing center once I see how many hidden $$ are required to get truck on road. At least I can drive it with current axle if I take it easy..
I have another '66 F100 416 FE project waiting (back burner) I can use the current center and axles for.
Looks like its time I start to unload some not needed parts . . .
Edit add:
Spoke with Strange
They quoted 319.00 for a Chromoly 3"  They do not do Aluminum shafts
They did say the 3" shaft they do there are people running 2000 HP with that shaft
So far all 3 places have been very helpful. I would give them all a A+
I will call DynoTech in morning or wait for a return call before I bite the bullet and order one.
Wait times have been from 48hrs to a week & 1/2
« Last Edit: September 08, 2014, 04:48:25 PM by TimeWarpF100 »
Richard F
« Reply #11 on: September 08, 2014, 04:40:43 PM »
What is the advantage of alum vs steel?
TimeWarpF100
« Reply #12 on: September 08, 2014, 04:43:17 PM »
weight
Some may have a preference for "looks"  Kinda like I do
A lot of OEM stuff is going aluminum
Richard F
« Reply #13 on: September 08, 2014, 04:51:07 PM »
Is it just static weight or spinning weight?
fe66comet
« Reply #14 on: September 08, 2014, 04:55:11 PM »
It also saves weight at the most critical point, that is rotating mass. A lighter shaft is easier to accelerate and decelerate.
