Author Topic: C-6 Dowel - Crack  (Read 4517 times)
R-WEST
C-6 Dowel - Crack
« on: September 01, 2014, 08:52:29 PM »
Hopefully you can see the crack at the dowel in my C-6 bellhousing.  Is it ruined?  Fixable?
I THOUGHT I had the camera set to 'macro', but I guess I didn't.   :-\
Re: C-6 Dowel - Crack
« Reply #1 on: September 01, 2014, 09:44:17 PM »
Unless the dowel is really loose in the hole, I'd use it as is.  Its for alignment only; there's no force on it once the trans is bolted up to the block.
« Reply #2 on: September 01, 2014, 10:29:59 PM »
I agree with Jay.  You should have no troubles running the trans as-is.  My guess is that somebody at one time pried the trans off (due to stuck pins), and the bending cracked the boss.
- Bill
R-WEST
« Reply #3 on: September 01, 2014, 10:43:57 PM »
Phew!!  Super - thanks guys!!  :D
That woulda' put a serious crimp in my project, otherwise!!
fe66comet
« Reply #4 on: September 02, 2014, 01:29:12 AM »
I have seen that a lot in cases where someone pulled the trans on the dowels with bolts. Even seen them gone completely, in that case I wrap some foil around the bolts to center it. Yes it is crude I agree but if the housing is junk anyhow, why not? I ran a service van like that for 225000 miles and sold it to someone else still going.
