FE Technical Forum
how much horse power is on the table
Pages:
All
Topic: how much horse power is on the table (Read 18679 times)
Re: how much horse power is on the table
Reply #15 on:
November 22, 2011, 09:08:44 PM »
As for those balance tubes, have you seen these?
http://www.allcarbs.com/detail.php?pid=781&mfgn=1&ctgn=13&stt=0&gb=2
I fully agree they can't hurt (allebit they may not help either
) and will add that one could easily drill and tap the standard cover(s) to accept a right angle brass fitting with a small hose nipple. I've seen it done before.
Heck, even the newer style plastic quick change covers could be carefully drilled/tapped in the same manner.
Last Edit: November 22, 2011, 10:15:24 PM by machoneman
Reply #16 on:
November 22, 2011, 09:25:19 PM »
I see it now on Holley's web site
.... I missed it somehow , I saw the 1x4 housing but not the quick change 2x4 , thats what I get saturday from Jegs
Reply #17 on:
December 19, 2011, 09:22:58 AM »
Ummmm - OK?
Administrator
Reply #18 on:
December 19, 2011, 12:33:05 PM »
LOL, those spammers sure are sneaky. I deleted the message...
GJCAT427
Reply #19 on:
December 20, 2011, 06:44:15 AM »
Eric, you can drill a standard set of covers, I`ve done it several times. I used brake tubing and drilled the hole undersize . Just tapped the tube in and never had any problem, you could also Loctite it in for added security.
Pages:
All
FE Technical Forum
