Author Topic: The Road to Drag Week 2014 - July 13  (Read 53873 times)
KMcCullah
Re: The Road to Drag Week 2014 - July 13
« Reply #15 on: July 15, 2014, 02:22:51 PM »
Jay I'm curious, how do you get the O-rings that you use on all the various things that you make with O-ring grooves?
Kevin McCullah
Qikbbstang
WARNING: Fat Man Fabrication strut conversion EARLY MUSTANG
« Reply #16 on: July 15, 2014, 03:35:29 PM »
I really hate it when "kits" you pay good money for are poorly planned and don't do what they are supposed to do. I take it the moving the wheels inboard is a combined 2" total and not 2" per side = 4" total?         You know most of these Rack & Pinion Kits are simply knowing which and who's parts from the endless automotive aftermarket to throw in the box -- they rarely make much other then small adaptors etc that go into their "kits".
Re:  ..."and the next project, which was to put the steering rack and lower control arm mount up into position.  This one is always a pain on this car, and let me warn anybody who is thinking about a Fat Man Fabrication strut conversion setup for an early Mustang that it is not a good kit, doesn't fit well, moves the wheels inboard 2" without telling you, etc. etc.  There are two big 1/2" through bolts that go through the rack and lower control arm mount, and also go through the original Ford lower control arm mounts on the car.  As you install the bolts you need to put three spacers on each side in place, and there's not a lot of room to work, so you end up doing this kind of blind.  And of course you have to assemble the steering linkage while you are doing this.  Another three hours of horsing around and I finally got this stuff all finished up."
« Reply #17 on: July 15, 2014, 03:51:34 PM »
McMaster Carr has any O-ring you may need, either in a standard size or in O-ring cord stock.  www.mcmaster.com
Re: WARNING: Fat Man Fabrication strut conversion EARLY MUSTANG
« Reply #18 on: July 15, 2014, 03:57:38 PM »
Believe it or not, that is 2" per side, or 4" total.  When I got the front end mocked up, I couldn't believe it.  I'm sure it was designed to allow really wide tires on the front of the car, but the least they could have done is said something about that in the advertising literature or on the web site.  I ended up cutting their lower control arms and TIG welding a 2" spacer in on each side to get back to the original factory track width.
68Rcodeman
« Reply #19 on: July 16, 2014, 12:37:11 AM »
Jay, Good luck, Love reading the weeks before and during. Wish I was closer, I would love to help!
        David
« Reply #20 on: July 23, 2014, 02:30:39 AM »
The rack uses the same bolts as the lower control arms? That seems weird. It sounds like they use a Mustang II track width and a Mustang II rack.
« Reply #21 on: July 23, 2014, 07:30:26 AM »
There is actually a big K-shaped steel plate that bolts up under the car, using the holes for the original lower control arms.  The new lower control arms and the rack are bolted to that plate.  The rack is a Pinto unit if I recall correctly...
fe66comet
« Reply #22 on: July 23, 2014, 07:54:49 AM »
More or less I am using the same set up for the ranger, I have a Heigd's universal Mustang II K member but haven't bought the arms or rack yet. I am using a 60" track so the rack extensions are required. Everything is supposed to fit right up but you know how that goes LOL
« Reply #23 on: July 24, 2014, 02:13:22 AM »
60" track in a Ranger? My 87 was 56" track stock and that was kind of wide requiring wheels with lots of backspace.
