Author Topic: 7.3 FE Ranger  (Read 9302 times)
fe66comet
7.3 FE Ranger
« on: July 10, 2014, 11:06:07 PM »
Thought I would post some pics if Jay says its OK?
Re: 7.3 FE Ranger
« Reply #1 on: July 11, 2014, 07:12:40 AM »
No problem Jon, go ahead - Jay
fe66comet
Re: 7.3 FE Ranger
« Reply #2 on: July 13, 2014, 04:34:26 AM »
Thanks now I just need to figure out how to pass with my new windows phone LOL.
fe66comet
Re: 7.3 FE Ranger
« Reply #3 on: July 13, 2014, 04:49:50 AM »
The engine with the wrong intake, just to keep me from dropping a bolt inside LOL
http://i1297.photobucket.com/albums/ag24/heintx/temporary.zpsd762a944.jpg
« Last Edit: July 13, 2014, 09:28:16 AM by jayb »
Re: 7.3 FE Ranger
« Reply #4 on: July 13, 2014, 09:28:46 AM »
Fixed the link above - Jay
« Last Edit: July 13, 2014, 09:30:51 AM by jayb »
fe66comet
Re: 7.3 FE Ranger
« Reply #5 on: July 13, 2014, 01:23:37 PM »
How did you do that? You are the man! Since the pic I have bolted down the heads and installed the rockers. I am playing around with my accessories right now to make the adaptors I need.
« Last Edit: July 13, 2014, 01:40:03 PM by fe66comet »
Re: 7.3 FE Ranger
« Reply #6 on: July 13, 2014, 02:52:55 PM »
All you do is go to Photobucket, click on the picture you want to display, then under "Links to share this photo" on the right, click on the link that is preceded by "IMG".  That copies the link to your clipboard.  Then paste it into your post here.
Now, I'm doing this from a PC, and you are using a smartphone if I recall correctly.  That may be a different procedure; I don't know...
fe66comet
Re: 7.3 FE Ranger
« Reply #7 on: July 13, 2014, 07:29:34 PM »
That's the way I used to do it now the site is different since I got my new phone. I just need to figure it out I guess. Thanks BTW did you get my money order? I got it out Wednesday  so you should see it soon.
fe66comet
Re: 7.3 FE Ranger
« Reply #8 on: August 02, 2014, 08:38:16 PM »
I picked up my 90mm Wilson throttle body, ordered my CVR water pump and sleeve for my EGR plate. The throttle body is huge but the cost was bigger, they sure are proud of that thing. At 3.5 inches it is a monster that's for sure. The difference between the 75mm EGR spacer and 90mm throttle body is major to say the least.
TimeWarpF100
Re: 7.3 FE Ranger
« Reply #9 on: August 10, 2014, 05:35:13 PM »
Cool Project!
Is this the truck its going in?
Looks like an older model JD?
TimeWarpF100
Re: 7.3 FE Ranger
« Reply #10 on: August 10, 2014, 05:39:06 PM »
Boneyard Ranger?
fe66comet
Re: 7.3 FE Ranger
« Reply #11 on: August 10, 2014, 07:53:49 PM »
No I stripped the frame from that truck and mirrored it to box my rear rails, it is going in the four banger truck pictured. I am going to stop all the junk under the hood and move the air box behind the dash, Vintage air makes a mini unit that should fit. After I get it all stripped out my plan is an aluminum firewall and floor to make more room. Header wise I am going with Doug's D627s into a 3" X pipe with dumps. I still need a TKO 600 and American transmission 18 LB flywheel also along with a RST twin Mcload clutch. I will of course need a  cage, seats, wheels tires and other goodies but for now I am going to get it rolling with the four cylinder stick and 9" so I can have time to do other work on the body and drivetrain. I am also planning a carbon fiber hood, sheeting the doors in carbon fiber and installing aftermarket glass to shave some more weight. The other plan in front is also a Mustang II coil over front end to loose a few hundred pounds in the front axle and steering box.
