Author Topic: Mechanical water pump for 500+ cubes  (Read 5316 times)
KMcCullah
« on: June 30, 2014, 05:18:12 PM »
So I'm close to building my stroker and I just realized I haven't considered my water pump. What do I need here? This is uncharted territory for me. I've found a few old threads where stock pumps supposedly worked. That would be good for me because I'm almost out of fun bucks. But with a lot more cubic inches than stock it seems like I would need more than a stock pump. Whatever I settle with has to be mechanical. Cylinders are siamese if it matters. Pulleys are early 70's truck diameters. What do I need guys? Edit: sometimes street driven also.
« Last Edit: June 30, 2014, 05:40:13 PM by KMcCullah »
Kevin McCullah
Re: Mechanical water pump for 500+ cubes
« Reply #1 on: June 30, 2014, 06:24:56 PM »
For sure an Edelbrock pump will work up to 900+ horsepower.  I imagine a stock pump would work up to at least 600, but have usually gone the Edelbrock route, so I don't have any personal experience.  No problems with the stock pump at 500 HP, that's for sure...
fastback 427
« Reply #2 on: June 30, 2014, 06:34:19 PM »
I have a dove aluminum pump I bought 18 years ago and love it. Dropped the temp 30° in my old 12 to 1 390. Paid 250$. Have a cast iron evans on my 406, paid 170$. Jury is still out on that one though.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
« Reply #3 on: June 30, 2014, 11:35:07 PM »
WerbyFord did a test on the "other" forum. Below is a link. He was using a mild engine, but I think the general info would transfer. I agree with him, pulley's can be as important as the pump.
http://www.network54.com/Forum/74182/thread/1377437235/Cool+Shootout+
And a condensd version:
http://www.network54.com/Forum/74182/thread/1381517465/High+flow+water+pumps-
KMcCullah
« Reply #4 on: July 01, 2014, 07:45:24 AM »
Werby's testing is what got me to thinking about using a stock FoMoCo pump. But his test platform was a mild 390. Not a 500+ ci engine. I suspect his findings would be dramatically different if he used a much higher HP engine for testing. For my deal I would rather error on the side of caution and run a high. volume pump.
Well... I better get busy and dredge a few bucks out of the wife's purse.  ::)
Edited for red neck nomenclature.
« Last Edit: July 01, 2014, 07:53:29 AM by KMcCullah »
Kevin McCullah
