Author Topic: elctric water pump pulley workaround?  (Read 3239 times)
fe66comet
« on: June 29, 2014, 08:16:25 PM »
I am going with Jays water pump manifolds and want to use 351 Windsor brackets to run serpentine belts. How are you guys working around the absence of the water pump pulley? I see lits that are simply an idler pulley mounted in the same location but the size of the CVR 55 GPH pump does not permit a pulley to be mounted there. Was just wondering what you guys came up with? Thanks Jon
