Author Topic: The Road to Drag Week 2014 - June 22  (Read 41545 times)
« on: June 23, 2014, 12:37:55 AM »
Dyno weekends tend to be exhilarating and frustrating all at the same time, and this one was surely that!  When I wrote my last update I figured I'd be spending all weekend wiring the EFI system onto this engine, and would be lucky to get it running.  That all went out the window on Monday when I emailed Scott Clark and told him that I probably wouldn't be ready to run this weekend, because I didn't have the engine wired and I wanted to have it up and running before he drove up with his double throwdown, triple whammy 8 oxygen sensor tuning setup.  But in his return email Scott pointed out that he was not tied up on Friday, and if I could take Friday off he would come up and help me wire the engine, and we could get it running and tuned over the weekend.
Well, I had another errand that I had to run on Friday morning anyway, so I had already taken the day off.  Scott had to drive up from Omaha to my place, and I figured with both of us working on the wiring we might be able to knock it out by the end of the night on Friday.  So we made the arrangements, and I spent some time during the week getting all the mechanical stuff done for getting the engine running on the dyno.  On Thursday night I was clipping part of the wiring harness out of my Shelby clone and putting it in place on the engine, and at the end of the night on Thursday, for once it appeared that I had overestimated the time it was going to take to get the project done; it seemed like between the two of us Scott and I could indeed get the wiring done on Friday.
Friday I got back from my morning errand by 11:00 or so and started working on the wiring shortly thereafter.  Scott showed up around 2:00 and between the two of us we had it finished up and were ready to start the engine by 6:00 PM.  About that time another guy that Scott knows, Mark Dahlquist, also showed up.  He drove down from Fargo ND to meet up with Scott and drop something off with him, and he hung around to help out with the engine.  I was really lucky to have both of those guys here to help out.  Some of you may know that Scott is kind of the EFI tuning guru for a lot of motorsport teams; he tunes for Bischoff and Ray Barton at Engine Masters, and of course those teams always do well.  He also tunes for some of the Bonneville teams, and he is actually making his living at this point tuning engines.  I hadn't met Mark before this weekend, but he is also an Engine Masters competitor; his first year was last year, and he finished 9th (I think) with a Pontiac engine, with Scott tuning the engine for him.  The most recent issue of Popular Hot Rodding has a writeup on Mark's EM engine.  Talk about qualified assistance!  I'm practically a newb compared to these guys.
Anyway, after Mark showed up Scott spent some time setting up the Megasquirt MS3X EFI system, and then we tried to start the engine.  First time out on this stuff you are always concerned about getting a good signal from the crank sensor.  I was using a Ford VR sensor on the crank target wheel, and a Cherry digital sensor for the cam position sensor.  After several tries we got the engine started, but I shut it off right away because we hadn't put coolant in the engine yet.  When assembling this engine I had been concerned about internal water leaks, so I had decided that the first thing I was going to do was to run the engine on the dyno with a radiator, so that after the water temp came up I could dump in some Moroso ceramic sealer and circulate that through the engine for a while to seal up any seepage that might be present.  After we knew the engine would start, I got to work setting up the radiator and the cooling hoses.  Mark had the idea to put some hooks in the ceiling and hang the radiator from a couple of tie down straps; that worked out very well, and shortly thereafter I had the cooling hoses attached to the water pump and the thermostat housing, and the electric fans wired up.  I filled the engine with distilled water at that point, checking carefully for any leaks, but there weren't any, so that was a good sign.
Next we fired up the engine, but Scott was concerned about the crank signal because the engine wasn't running that well.  The MS3X system has a diagnostic mode where you can watch the signal from the crank sensor, after conversion to a digital signal (the Ford VR sensor puts out an analog or sine wave signal).  This is just like having an oscilloscope screen on your computer so you can watch the crank and cam signals.  This diagnostic mode was showing errors with some of the teeth on the target wheel; the sensor was losing teeth, and so the missing tooth on the wheel was not being detected properly.  We messed around with the sensor airgap to try to resolve this problem, and it seemed like it mostly went away, but still would give us some intermittent errors when the engine was running.  In any case though, we could get the engine started, and it sounded pretty good.  Finally around 10:00 PM we just decided it was getting too late and that we needed to run the engine to get the sealer circulating; I didn't want to leave it overnight with water in it and no sealer, and also I wanted to circulate the sealer and then later drain the coolant out of the engine, per the sealer's instructions.  So, we fired it up with a less than ideal crank sensor signal and started warming up the engine.  It wouldn't idle much below 1500 RPM at this point, but that was OK for Friday night's purposes.  After the engine was warmed I dumped in the bottle of sealer, put the cap on the radiator, turned on the electric fans, and let the engine run.  The CVR water pump seemed to keep right up with the cooling system; it did gradually warm over 30 minutes from 180 degrees to 210 degrees, but by that time the sealer was well circulated and we had run the engine twice as long as was recommended by the sealer instructions, so we shut it down and called it a night.  Scott and Mark took off, and around midnight I came back out to the shop, drained the water out of the engine, and then went to bed.
Saturday morning I was up early, taking the radiator off the engine and hooking up the dyno's cooling system.  After Scott and Mark arrived back we got to work on the startup procedure for the engine again.  We continued to have trouble though with the crank signal.  For a while it would work just fine, with no errors, then suddenly we would get bunches of errors all at once, and the engine would sound like crap.  One thing we tried was changing the lead on missing tooth of the crankshaft target.  My target wheel, like the Ford ones, has a tooth every 10 degrees around the wheel, with one tooth missing to allow the EFI unit to sync up to the wheel, and know where top dead center is.  I had the tooth #1, which is the first tooth after the missing tooth, set for around 65 degrees BTDC.  My target wheel is drilled for multiple mounting positions, in 20 degree increments, so we tried advancing the target wheel so that tooth 1 was at 45 degrees, and retarding it so that tooth 1 was at 85 degrees, but still couldn't get a good consistent crank signal.  This was the same issue that was dogging me at Drag Week in 2011, so we really needed to get this problem solved.  Scott began promoting use of another Cherry digital sensor, like the one we were using for the cam sensor, on the crank; he had recently had good luck with those.  I did have one spare Cherry sensor, so finally I installed one in place of the Ford VR sensor.  There was an immediate improvement in the cranking signal from the sensor, and the engine began starting much more easily.  We had it up and running for several minutes at a time while Scott tuned the A/F ratio and logged the sensor diagnostic data.  We were still seeing some drop out of the crank signal, though, so Scott thought we should try moving the target wheel again.  After I did that, suddenly we had nothing for signal, and the engine wouldn't start.  Mark went into the dyno room and wiggled the sensor, and found that it was loose!  This was my fault; I had only put the nuts that held the sensor in place finger tight, and they had come loose and the sensor had started to wobble around.  I tried to put the sensor back in its original position, but it looked like the sensor body had been dinged by the target wheel, and it just wouldn't work anymore.  So, our crank sensor was no longer working.
We thought about going back to the Ford VR sensor, but I did have a couple of other digital output sensors made by Hamlin that would also work.  Unfortunately the Hamlin sensors wouldn't physically fit in the crank sensor mounting bracket that I had machined for this engine.  So, in the end what we decided to do was take the Cherry sensor out of the left valve cover, use that one as the crank sensor, and put one of the Hamlin sensors into the valve cover to act as the cam sensor.
All this screwing around with the sensor took the whole morning and most of the afternoon, but when we got the new sensor configuration set up it seemed to work really well.  Finally we were ready to make some dyno pulls.  We started with pulls from 3000-5000 RPM, and gradually worked our way up to 5000-7200.  The engine sounded really good, but was down just a little bit on power compared to what I was expecting.  (By the way, this will be disappointing for some of you guys but I won't be sharing any of the dyno results from this engine just yet.  There are Drag Week competitors watching this web site, and I don't want to tip my hand before the event.  I will post the dyno results on this blog in September, after Drag Week has started.)  While we were doing these pulls Scott was messing around with a software feature in the MS3X called VVT.  VVT stands for variable valve timing, and it allows the MS3X to control the variable valve timing actuators found on some modern engines.  What he was discovering, though, was that despite the fact that this engine doesn't have VVT actuators, the MS3X can log the position of the cam sensor during a pull.  This would allow us to see the cam with the cam sensor on it advancing or retarding during the pull!
Back in 2006, on the second SOHC I ever built, I added proximity sensors and targets to the crank and both cams, and ran multiple experiments over a 4 week period trying to determine exactly how much the cams were moving with engine speed.  The datalogging capability I had back then was SLOW, and so I ran the pulls really slow, and tried to get data every 500 RPM or so.  It was quite the torture test for the engine, and gave me some surprising results.  What I found was that while the right cam retarded with RPM (as everybody always said they did), the left cam actually advanced with RPM.  This led to about a 3-4 degree variation in cam timing between the two cams, so ever since this I've been setting up my SOHC engines with the right cam advanced 3-4 degrees compared to the left cam.  The two graphs reprinted below summarize all this data:
The "calculated" vs. "measured" data in the second chart refers to calculating the difference between the two cam signals when they are compared to the crank signal, and then a directly measured difference between the two cams.  The data was taken on different days, so there are some minor differences, but the general trend is the same.  Now that we could see this same data logged directly from the EFI system, I was anxious to get some confirming data.
The cam sensor was on the left cam, so we were expecting it to advance.  After the next pull, the data seemed to show that the left cam was retarding, and by quite a significant amount!  However, there was some question about the data itself; could the direction be wrong?  We weren't sure, but in any case we were seeing something like 8 degrees of change in the cam phase.  Yikes!
While we were thinking about this, we decided to go ahead and put Scott's 8 O2 sensor setup on the engine.  Here's a picture of the engine with this setup installed:
This setup uses the closed loop corrections available in the MS3X to monitor the O2 sensors in each primary pipe, and then hold the injectors open a shorter or longer period of time, to try to hit the targeted A/F ratio in each cylinder.  After getting all the O2 sensors installed Scott configured the CAN communications in the software, and we were ready to run.  We targeted the A/F at 12.6:1, and ran the pull hoping for a significant power increase.  We did see a bump of about 10 HP, but it wasn't a real big improvement.  This basically meant that the sheet metal intake I had built for this engine, previously known as "the steaming pile" because of the problems it seemed to give us in 2011, was actually pretty good.  In fact, Scott was praising the steaming pile by the end of the day Sunday as one of the better sheet metal intakes he's seen with respect to fuel distribution.
Last time I ran this engine on the dyno, in its 585" form, it had wanted to run a little lean.  So we ran another pull, changing the targeted A/F ratio to 13:1, and the engine really picked up, to the tune of about 18 HP.  That was good news.  We continued to log the cam data, and we continued to see what appeared to be a big retard in the left cam during the pull.  It was about the end of the night on Saturday, so we made plans for the next day and called it a night.
This morning (Sunday), the first thing I did when getting out to the shop was to take my second Hamlin sensor, and install it as an auxiliary cam sensor in the right valve cover.  I was certain that the right cam would retard with engine RPM, so if the right and left cams were moving in the same direction, we would have confirmation that both cams were retarding.  Thinking about this a little more, I began to suspect that the long, slow pulls I had done on the test engine back in 2006 were not really reflective of what would actually be happening at the track, and that maybe with the rapid logging available using the MS3X, and a normal dyno pull rate of 300 RPM/sec (rather than the 25 or 50 RPM/sec I was using in 2006) might make the cams behave differently.  When Scott arrived the first thing we did was run the test to look at the left and right cams together.  Sure enough, they were both moving in the same direction, and both retarding a significant amount.  Here are four screen shots from the MS3X datalogger that show this effect:
The vertical blue line running through the graph has numbers next to it, and these are the ones we want to pay attention to.  The top graph shows engine RPM, which is about 1200 at this point in the log.  The bottom graph shows the cam sensor angles.  These are phased arbitrarily, so what we are looking for is changes in these numbers, not absolute values.  The red line is the right cam sensor, and the white line is the left cam sensor.  At this point in the log the right cam is at 127.6 degrees, and the left cam is at 156.9 degrees.  Off to the right of the vertical blue line, you can see the engine RPM during the dyno pull.  Also, the left cam line goes vertical in the middle of the pull, but that's not real data, that is just a noise spike.  Here are the other graphs with the blue line positioned at various points during the pull:
In this graph we are at the start of the pull, 5000 RPM, and the right cam has retarded to 116.7 degrees, while the left cam has retarded to 153.7 degrees.  Here's the next graph:
Here we are at 6360 RPM, and the right cam has retarded to 115.3 degees, while the left cam has retarded to 149.7.  Here's the next graph:
In this case we are almost at the end of the pull, at 7180 RPM, and the right cam has retarded to 113.7 degrees, while the left cam has retarded to 147.0.
To be honest I'm not really sure I believe these numbers; that is a tremendous amount of chain stretch, and it just seems unreasonable to me.  The difference between the right cam at idle (127.6 degrees) and the right cam at 5000 RPM (116.7 degrees) is just not believable.  Also, the left cam is retarding more during the pull (6.7 degrees) than the right cam (3.0 degrees).  This is in spite of the fact that as the engine spins the length of the chain between the drive sprocket and the left cam is shorter than the length of the chain between the drive sprocket and the right cam, in the direction of engine rotation.  If anything, the right cam should be retarding more than the left cam, if indeed they are both retarding as this data seems to suggest.  I can see several potential sources of error in this data, including variability in the targets (which are just bolt heads), and frequency response of the Hamlin sensors.  Just doing a quick calculation, at 7000 engine RPM the cams are spinning at 3500 RPM.  This is 58.33 rotations per second.  To discriminate 0.1 degrees of accuracy the update frequency of the sensors must be 1/(58.33 * 3600), or about 210 KHz, which is pretty fast for a magnetic sensor.  Even to discriminate 1.0 degrees the frequency response still has to be 21 KHz.  I need to do some research on the sensors to see if they are up to the drill here.
In any case more happened on Sunday than I have reported so far; I will update this post tomorrow with more information on Sunday's tests - Jay
« Last Edit: June 23, 2014, 09:26:43 AM by jayb »
Re: The Road to Drag Week 2014 - June 22
« Reply #1 on: June 23, 2014, 07:13:19 AM »
Very interesting! I'm sure you have thought of it and maybe now isn't the time with Drag Week coming up but....
Can you rig up some kind of crude plexiglass or Lexan covered front cover and video the action of the chains and adjuster to determine if they really do retard that much? Hate to think a good cover may have to be sacrificed to do.
« Reply #2 on: June 23, 2014, 07:51:32 AM »
According to legend Sneaky Pete Robinson did exactly that when developing his fuel motor in the 1960s.  He put a degree wheel on each cam, and stood in the dyno room with a timing light and oil spraying everywhere, watching the cam timing!  I won't be doing anything like that LOL...
« Reply #3 on: June 23, 2014, 01:42:40 PM »
Glad to see it up and running, hope it will stay leak free for you!  How is the torque with that intake set-up?  Good enough to take some gear out of the car like you did with the Galaxy?  Hopefully the power will come around with some run time, and additional tweaking.  Joe-JDC
900HP
« Reply #4 on: June 23, 2014, 04:21:23 PM »
Jay, what an incredibly detailed account of this weekend's events! :o  I was very grateful to be included this weekend and even though I didn't do much I sure had a great time!  I hope to visit you again sometime.  I also wanted to point out that it's still possible you are looking at crankshaft degrees which would make the cam degree error reading 1/2 (unless you verified that aspect after I left).
-- Mark Dalquist
« Last Edit: June 23, 2014, 04:23:07 PM by 900HP »
« Reply #5 on: June 23, 2014, 04:25:17 PM »
Jay
Thanks for taking the time to write all this down for us.
It's fascinating reading.
« Reply #6 on: June 23, 2014, 04:57:13 PM »
Jay, I am no electrical engineer, but any chance you could be seeing any kind of interference that would change the readings of the sensors or inductance along the route of the wire?
Even with tha being said, looks like the numbers could be a harmonic causing some chain "waggle" at different rpm
Does anyone make a gear drive or a belt drive?
« Reply #7 on: June 23, 2014, 05:17:30 PM »
FPP made a belt drive back in the early '80s, but I only ever saw one on Rons engine. And I thought I remembered Sneaky Pete ran a gear drive at one time, or somebody did, but they were all one-off designs and never really sold.
Wait till September? What is this, a season show ender? Another "Who shot J.R.?"  ;D ;D
Jay, you may not want to totally discount the less retarding on the right cam. Even though the chain from the drive sprocket to the right cam is longer, there may be something other than chain stretch going on. Momentum has a way of making chains follow an arc pattern, even on drive sides. If the chain were doing something to that effect, it could be "pulling" the right cam ahead, or advancing it, relative to the left cam. The open chain area between the left and right cams is fairly significant and even though there is a short bottom guide, it may not be enough. That was the reason for the discussion earlier about modern engines and their chain controlling devices. It's very important in high revving engines.
There is a top guide, but the chain arc may not simply be "up and out", it could also be "down and in". You can see this on blower drives and just about any belt/chain drive system, and it all depends on length, speed, applied torque etc. as to whether its "up/out" or "down/in". Something that only sophisticated strobe or very high speed cameras could detect....the stuff that manufacturers have access to. ::)
Just a thought.
Boy do I love carburetors and simple electronic ignitions...lol
« Reply #8 on: June 23, 2014, 09:51:46 PM »
This week's update continues here.  After running the pulls with both cam sensors installed, and seeing that they were more or less repeatable for the cam phasing shift, I decided that the next logical course was to change the cam timing.  I had the right cam degreed at 105 and the left cam at 108, but on the engine stand I had checked piston to valve clearance all the way up to 99 and still had about .050" on the intake valve, so I had some room to advance the cams to compensate for the chain stretch that the sensors seemed to be indicating was happening.  About the time I got started on the cam timing change Mark had to leave, and then my friend Kevin R showed up to help out.  Always nice to have some wrenching help on the dyno.
I got started on the cam timing change by pulling the right side inspection cover so I had the opportunity to look at the witness marks from the chain hitting the tensioner arm.  What I saw indicated to me that the chain was still too loose; notice the long stripe in the machinist's blue dye on the top of the tensioner arm:
I think that's too much contact, even after some dyno pulls.  I like to see just a little nick on that tensioner in the dye; after the engine went back together and I had tightened up the chain bolt an eighth of a turn, I made a few more pulls, this was what the mark looked like:
So, next it was on to the timing change.  Now if this had been last year or the year before, my friend Hemi Joel (aka Captain Stabbin') would have been here with his video camera, and he would have recorded the next events for posterity.  Scott asked me how long it would take to change the cam timing.  I said, "Oh, about 20 minutes per side."  When Joel finds out he missed the opportunity to get that on tape, and then the following 5 hour debacle to get the cam timing changed, he will be very disappointed LOL!.  Advancing the right cam was complicated by the fact that I was out of adjustment on the alignment pins that move the cam gear with respect to the camshaft itself.  This meant that I had to move the sprocket on the timing chain by one tooth, and then go back to the most retarded position for the alignment pin.  After pulling the valve cover and loosening the chain, I removed the sprocket and rotated it one tooth.  About an hour later I figured out that I had moved it the wrong direction.  The first thing that happened after I got the sprocket back on was I rotated the engine over by hand to check the cam timing, but hit a dead stop.  Uh-oh, that was a piston running into a valve!  Thank goodness I didn't try to rotate the engine over with the starter, or I would have bent a valve for sure.
I scratched my head for a while trying to figure this out, and eventually decided to pull all the rocker shaft clips on the right head so that there was no way the valves on cylinders 1-3 would open, and then back the adjusters off the rockers on cylinder 4 to minimize any potential piston to valve contact.  Then, I was going to try to rotate the cam to check the timing on #1 so I could figure out where I went wrong.  Along the way I loosened up the timing chain in case I had to pull the sprocket off again.  And then I made another cardinal error; I rotated the crank with the timing chain loose, and all the rockers on the left head still on the valves.  After rotating the crank a few degrees I heard a pop, and then another couple of pops.  On the second set of pops I notice the timing chain jumping, and it dawned on me that with the chain loose, and the left cam hard to rotate because of the valve spring pressure on the cam, that I had just jumped a few links on the left side sprocket.
At this point I was basically back to square one on the cam timing for this engine.  I had to start completely from scratch, which is not easy with the front cover on the engine.  With the cover off, you can line up the colored chain links with the dots on the timing gears, and know that you are very close right from the start.  But with the cover on there is no way to see the chain and center timing gear, and you can't move the chain with respect to the center timing gear anyway.  I ended up taking the bolts out of the left cam sprocket so that the left cam wouldn't move, going back to the right cam and getting it timed correctly, and the pulling the rocker arms off the valves on the left cam, getting that cam lined up, and then degreeing that one.  It is a lot easier to write this than to actually do it LOL!  It took me until 5:00 on Sunday to get this done, and get the engine back together.
When I did have the engine back together, though, I had changed the left cam to 103 degrees (from 108), and the right cam to 102 degrees (from 105).  If the retard numbers we were seeing were accurate, this would put the cams right around straight up in the RPM range of 5000-7000.  I started the engine with some trepidation, fearing I may have done some damage to the engine during the whole cam timing debacle, but it lit right off and sounded fine.  After warm up we ran the dyno pull AND.....   the engine was down 20 HP.  Sounded good during the pull, though.
After that pull we pretty much called it a day.  I had a whole list of things I was going to try on Sunday, but due to the cam timing fiasco I didn't get to try anything but that.  After this I was even more suspicious of the cam timing that was being reported by the MS3X, because if those numbers were right the engine should have picked up with the cam timing change.  Also, today I got some more information on the Hamlin sensors I'm using for cam timing, and their specs are really not ideal for this application, so I'm going to get some of the sensors that I used with my original cam timing experiments several years ago, which are very fast and accurate, and plug those in to see what numbers they give.  Scott also told me he is going to check with the Megasquirt designers to see if what we are trying to do is even possible, or if there is some kind of electronic signal processing going on that is preventing us from getting accurate cam timing data.  We will see how all this works out in the next week.
Other experiments I want to run are to move the throttle bodies to the top of the intake manifold, rather than the front, to see if that improves performance, and to turn down the dry sump oil pressure a little (currently running at 80 psi) to save power.  I'm also not getting very good crankcase vacuum from the dry sump, so I may have a leak to track down there.  I fully expect to spend another full weekend on the dyno with this engine next weekend, to try to iron out these little bugs and really dial this engine in.  But I'll tell you guys something, this thing sounds like a million bucks at speed.  Next weekend I'll run a video of a pull so you can hear it.
I'll post another update next Sunday night - Jay
« Last Edit: June 24, 2014, 01:06:14 PM by jayb »
« Reply #9 on: June 23, 2014, 09:53:50 PM »
Joe, the torque curve is very broad and flat, but it is down a little from where I expected it to be.  According to Pipemax my intake runners are a good 3" short, and that is one good reason for the torque being a little lower.  But its not bad, really...
« Reply #10 on: June 23, 2014, 09:55:54 PM »
-- Mark Dalquist
Mark, for sure we are looking at crankshaft degrees on the MS3X, but still that is a lot of error, more than I saw the first time I ran these tests back in 2006 or so.  In any case it was great having you here, and you are welcome back at any time - Jay
« Reply #11 on: June 23, 2014, 10:07:04 PM »
Ross, electrical interference is certainly a possibility, but these are digital sensor outputs so I think that explanation is not all that likely.  And I think for sure there is a harmonic in the chain causing the timing to move around; I saw this with the first data I collected on the phenomenon back in 2006.
Here are a couple of photos of gear drives for the SOHC.  The first one is a custom drive, I think, and the second one is the one that Sneaky Pete Robinson developed.  I think that my friend Brutal Bob may have one of the Sneaky Pete drives:
Needless to say, I don't have access to anything like that at present.  I'm thinking I need to really figure out if the data I'm collecting on the cam timing change is accurate, and then make any changes from there...
« Reply #12 on: June 23, 2014, 10:08:58 PM »
Who shot J.R. LMAO!!  ;D ;D
cobracammer
« Reply #13 on: June 24, 2014, 09:25:03 AM »
I would have thought that the larger pin double roller chains from Munro wouldn't stretch AS MUCH as the stock chains? If anything, wouldn't the cam timing reflect that?  At 103 and 102, does that mean your experiencing Less stretch or more stretch than normal (and I use normal sparingly with SOHC's)?  LOL
Jason
« Reply #14 on: June 24, 2014, 10:16:19 AM »
That was also my thought, but I don't think we've proven anything yet.  For one thing, I'm not confident that the data I'm getting from the sensors is accurate.  I need to work on that issue this week.  For another, the valve springs on this engine are quite a bit stiffer than the springs on the engine I had tested previously, so comparing this chain with the .250" pins and these springs is different than comparing the stock type chain with much lighter springs.  So, the jury is still out...
