Author Topic: M S D fuel injection  (Read 8087 times)
bn69stang
« on: June 16, 2014, 05:44:29 PM »
Anyone running an M S D setup on there fe yet , input wanted on them vs a carb as far as hp and tq .. Bud
66FAIRLANE
  • Andy
Re: M S D fuel injection
« Reply #1 on: June 16, 2014, 07:45:21 PM »
I know a guy using it on a small block. Says its better in every department. Ultimate peak numbers might be similar but he says it's just stronger through the rev range, starts better, idles better, tip in better, fuel economy better.
bn69stang
« Reply #2 on: June 16, 2014, 07:50:38 PM »
Thanks Andy for the feed back , much appreciated .. Bud
« Reply #3 on: June 16, 2014, 09:22:37 PM »
We ran one on a mild 445 engine.  Seemed like a nice kit - more capability than the competing FAST system.
https://www.youtube.com/watch?v=numyIMtD_T0
bn69stang
« Reply #4 on: June 17, 2014, 05:12:06 PM »
Thanks Barry , im really looking at it for the the tuning aspect and minus a $ 700.00 credit on my carb with summit and i have my  tko 500 sold , and the edelbrocks already and would pay the difference .. Bud
bn69stang
« Reply #5 on: June 17, 2014, 05:15:51 PM »
And when you said a mild 445 , how much camshaft ? , and hp ? .. Bud
« Reply #6 on: June 17, 2014, 05:30:46 PM »
Truck oriented 445 cube 390 stroker.  As basic as they get with a twist.  Iron D2TE heads, Comp XE262 cam with 218/224 duration and .513 lift, 9.8:1 compression, Performer (not RPM...) intake.  Unusual item is a MSD Atomic EFI.  A pretty cool little unit - still tuning and hope to eventually get over 400 HP.  As of today we are now at 393 horsepower at 4800 RPM and 508 pounds at 3100 RPM.  We've been trying to get more power and keep getting more torque....  Pretty strong for a simple build.
bn69stang
« Reply #7 on: June 17, 2014, 05:37:02 PM »
That s a healthy truck motor for sure , keep us posted Barry ..Bud
66FAIRLANE
  • Andy
« Reply #8 on: June 17, 2014, 11:27:00 PM »
Damn that!!  ;D
GJCAT427
« Reply #9 on: June 18, 2014, 05:07:43 AM »
Barry, are they gonna put it in a pickup or something bigger? I have a 56 C600 I`m thinking of putting a 390ish in. Will be a toy hauler that will look like a very big pickup.
« Reply #10 on: June 18, 2014, 07:17:43 AM »
I haven't tried the MSD, but originally didn't like the idea because it adds a booster to the venturi, adding restriction that I can't see a good reason for.  Especially with the good injectors nowadays.  I am sure it helps turning the corner into the airflow due to packaging, but most others just stand the injectors up a bit and have a more open airflow path
However, guys love how it runs.  I haven't heard one unhappy customer
One warning, it claims that it can be run without a return, true, but you need a square wave voltage controller for the pump, which adds about 500 to the cost. In most cases, I would think running a regulated return would be more effective and probably more reliable long term
bn69stang
« Reply #11 on: June 18, 2014, 06:58:49 PM »
Thanks for the feed back , the thinking wheels are turning , though i have spent alot so far .. Bud
