Author Topic: Windage tray question  (Read 4779 times)
Fine69mach1
« on: June 14, 2014, 06:09:30 PM »
Does anyone know if a windage tray will fit with a stock 390 oil pan with a 4.125 stroke crank.?
Any suggestions if not?
Thanks
1969 Mustang Mach1 S code
KMcCullah
Re: Windage tray question
« Reply #1 on: June 14, 2014, 10:17:03 PM »
I don't think the pan will be a problem but if your windage tray is the factory one it's going to be close.
Kevin McCullah
« Reply #2 on: June 14, 2014, 11:48:38 PM »
Pretty sure with the 4.125" crank that the stock FE windage tray will fit.  I've had 4.25" stroke engines fit with the stock windage tray and no mods, although I've heard other people had problems with that combination.  In any case, its not a big deal to cut a slot or two into the factory windage tray if you need clearance for the rod bolts.  There won't be any block or pan clearance issues.
Fine69mach1
« Reply #3 on: June 15, 2014, 09:36:50 AM »
Thanks for the replies guys.
