Author Topic: FE Timing Cover  (Read 64556 times)
NewFalconOwner
Re: FE Timing Cover
« Reply #15 on: June 11, 2014, 11:26:27 PM »
cool,, I will watch for updates :)
Bullitt
Re: FE Timing Cover
« Reply #16 on: June 11, 2014, 11:57:29 PM »
Any plans to offer one without the fuel pump provision?
Josh
Re: FE Timing Cover
« Reply #17 on: June 12, 2014, 07:27:29 AM »
Hmmmm, I could do that I guess, just by machining off the parts of the casting used for mounting the fuel pump, and not putting the holes for the fuel pump in.  What is your reason for not having the fuel pump mount on the cover?  Just one less gasket?
NewFalconOwner
Re: FE Timing Cover
« Reply #18 on: June 12, 2014, 08:51:05 AM »
that's a great idea without having the fuel pump holes, be great for my fuel injection setup..Im into one of those ones too
Re: FE Timing Cover
« Reply #19 on: June 12, 2014, 12:26:00 PM »
Jay, does it use a standard FE timing cover seal?  How big of a deal would it be to make it with a Cleveland seal?  That way you could change seals from the front without taking the timing cover off, plus you would be able to use some of the nicer teflon seals for use with vacuum pumps.
Re: FE Timing Cover
« Reply #20 on: June 12, 2014, 12:41:29 PM »
It does use a standard FE seal.  I confess I don't know much about the size of the Cleveland stuff.  Is the Cleveland seal the correct size for the rubber seal to fit around the OD of the FE crank spacer?  Do you know what the OD of the Cleveland seal is?
Re: FE Timing Cover
« Reply #21 on: June 12, 2014, 01:31:27 PM »
Pretty sure the sealing surface diameter is the same.  The cage of the seal is different though and of course it drives in from the outside.
JamesonRacing
Re: FE Timing Cover
« Reply #22 on: June 12, 2014, 01:43:23 PM »
I'm using one of these seals, PN T-13690 on my race engine with the Peterson Wet-Vac pump.  The seal fit into the recess in my HM marine timing cover without issue.  A  little pricey for a seal, but seems to do the job.
http://www.tritecmotorsports.com/Engine_Seals-Ford_Big_Block_A460-A600.htm
Re: FE Timing Cover
« Reply #23 on: June 12, 2014, 02:34:59 PM »
Thanks, maybe I'll pick one up and check it out.
Re: FE Timing Cover
« Reply #24 on: June 13, 2014, 07:52:19 AM »
Jay,
They look excellent. Assume the stock-type fuel pump will bolt up without issues?  What color will you powder coat the steel cover?  Satin black?
I happen to be in the market for 2; for a couple of 427 bare blocks just acquired... Will do a post on those soon.
Bruce
Re: FE Timing Cover
« Reply #25 on: June 13, 2014, 08:27:04 AM »
Yes, the stock pump will bolt up.  I was looking at making the removable cover finish available in different colors, Ford dark blue, black, and a chrome-type finish.  If you wanted satin black it would be no problem...
falcon428
Re: FE Timing Cover
« Reply #26 on: June 13, 2014, 12:04:53 PM »
Hope all the testing goes well, count me in for at least one of them when time comes.
'65 Mercury Comet w/ Pond Alum. 427, C6
'61 Ford Starliner w/ 352, C6
'68 Falcon w/ ProCharged FE, Lenco 5sp
'67 Country Sedan SW
'62 Falcon awaiting turbocoupe motor & tranny
'40 Ford Tudor Sedan all original
CaptCobrajet
Re: FE Timing Cover
« Reply #27 on: June 14, 2014, 05:59:15 PM »
Looking good Jay!
Blair Patrick
Bullitt
Re: FE Timing Cover
« Reply #28 on: June 14, 2014, 09:01:22 PM »
More or less thinking about EFI and with no need for the mechanical fuel pump provision and possibly a "cleaner" looking cover.
Josh
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: FE Timing Cover
« Reply #29 on: June 15, 2014, 09:49:43 AM »
Jay,
  Is there anything you dont do!?  ;) LOL That is an awesome setup for sure. I always wondered if someone at some time would make one. That is a very nice setup Jay! Keep up the good work 8)
Wes Adams FORD428CJ
64 Falcon 428FE
