Author Topic: drum brake shoe upgrade?  (Read 4162 times)
fe66comet
« on: May 17, 2014, 08:43:54 PM »
I decided to use my Comet 9" 28 spline rear for another project, question is whether the the upgraded high performance drum brake shoes are worth it? I am using the rear behind a 400 cube Boss engine, about 450 HP. I was just wondering if the street version shoes were a big improvement and has someone used them? Thanks Jon
« Last Edit: May 17, 2014, 10:27:39 PM by fe66comet »
C6AE
Re: drum brake shoe upgrade?
« Reply #1 on: May 18, 2014, 09:43:51 AM »
I have used them on several vehicles and they work as advertised - no fade, reduced effort at the pedal etc
On one set in particular it worked as well as adding a booster. I have gotten the brakes hot enough to boil the fluid without fade or damage to the lining
http://porterfield-brakes.com/
fe66comet
« Reply #2 on: May 19, 2014, 12:29:27 PM »
I guess I will go with the good ones, I am not going to have room for a booster and do not think disks in the back would be necessary  as the original drums were 8" and the 9" brake are 10". I am sure it will be plenty of stopping power with the good shoes.
