Author Topic: My first trip to the dragstrip  (Read 17641 times)
Ratbird
« on: May 05, 2014, 10:21:49 AM »
Didn’t do too well, but I had a blast. Made six runs with a best time of 15.125 with a reaction time of .623. (My average reaction time was .510) next time I'll just start on the last yellow and be much better.
The first run I drove right through the water and didn’t do a burnout. The starter had me roll down my window and explained that next time be sure to do a burnout, or drive around it. EVERYONE who worked at the track was awesome, really good people, and super helpful with everything. Sadly, my first run was the only one that the car ran right, the other 5 runs it was cutting out at different times. Not sure what it was, but at home it was running fine. The altitude at home is 6800, at the track it’s about 5200. I also had way too much spinning off the line the first 3 runs (it’s an open differential). The last two runs I did burnouts - I also revved at the line to about 5000 rpm and then feathered the clutch a lot better.  But every run I left a lot of time out there - either spinning, sputtering, or bad reaction. I made a ton of notes and feel I will do a lot better next time. Plus next time I’ll have a posi to go with my Centerforce dual friction clutch. I truly believe that if I could have got the car running cleanly and gotten off the line around .300 I would have been at 14.5ish range. Get the posi pumpkin in the car and I should be in the low 14's at a mile high.
And yes "Fastback 427", I'm hooked!
Any ideas what would cause the car to go flat during a run? I've never experienced valve float, but I image what I was experiencing feels like that. However, it happened once at about 4000 rpms in first gear. Another time it happened in 1st and 2nd, and another time it happened in 3rd. Usually around the 4500 - 5300 rpm range. It was a lot hotter than the car is used to. I had to let it cool down between runs because it was up to 215 degrees.
regards, Dave Jones
pure fun
Re: My first trip to the dragstrip
« Reply #1 on: May 05, 2014, 10:46:28 AM »
Congrats on your first outing...and a new hobby ;D
Just an FYI, reaction time wont affect your ET. The timer starts when you trip the lights. But it can lose you a race as the difference between your reaction time is compared to your opponents reaction time. So if you're .3 seconds slowe in RT, your opponent will win even if you beat him by .299 in the race.
I would look towards the ignition for the problem. Possibly a bad coil, weak points (if it's points ignition), plugs? Even bad or improperly gapped plugs or a weak condenser can cause the issue. Sounds kind of early to be running out of fuel unless it's dumping fuel in...and that would show in the plugs and exhaust.
Hope you find the issue soon.
Ratbird
« Reply #2 on: May 05, 2014, 11:09:05 AM »
Thx Doug, I'm learning more and more.
The ignition, coil, wires, and plugs are all new with about 300 miles on them. I have a Pertronix 2 setup. I'm running autolite plugs, can't remember the number but those are what someone advised when I told them I had Bosch in it. I have them gapped at .038, maybe I should go to the factory .035 gap.
Can too much timing cause the missing? I have it at 13 and a total of 37; maybe drop it back to 12?
I'm thinking fuel. I have too much rubber line from the pump to the carb, and it's 5/16. Plus the 59 T-bird has the original fuel line coming from the tank. I'm going to replace that with 3/8 all the way through.
Lots to do!
thx again
pure fun
Lenz
« Reply #3 on: May 05, 2014, 11:50:20 AM »
Congrats on that first outing, sounds like you had a good time ;D.  Without going back in time I think the plugs that were recommended to you were autolite 45's.
Hope you get it sorted out without too much trouble.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
KMcCullah
« Reply #4 on: May 05, 2014, 12:21:39 PM »
You were obviously excited. Better put a reminder list in the car for next time.
When I was a young guy I built a 1972 LTD demolition derby car. I was so damn excited in my first heat that I forgot to put my seat belt on! 3 broken ribs served as my reminder.  ::)
Kevin McCullah
« Reply #5 on: May 05, 2014, 12:49:28 PM »
A couple of pointers: First, you do not decrease the time by cutting a better light-the timer starts when the wheels break the beam, so a 2 second reaction time will not make the car slower.  If the engine is laying down above a certain rpm, then you are not getting fuel to the carb quick enough, or you have an aircleaner/filter issue, or fuel filter issue.  Since you have obviously driven the car harder than previously, some sediment may have moved around in the tank and clogged/partially clogged the fuel system at some juncture.  Check it out well, and make sure you have a vented fuel cap/tank.  Joe-JDC
« Reply #6 on: May 05, 2014, 01:23:31 PM »
Ouch, Kevin!! That's a painful, but unforgetable, reminder!
Since the ignition is new, I would look towards the fuel as you thought and Joe suggested. Although, I have seen coils cause this same issue. I might try throwing an old one on if I had one just to eliminate it as a possibility....and it's a quick free check. Even new parts can and do have issues sometimes. That 5/16 fuel line is marginal at best on a stock engine. Definitely not suitable for any kind of performance. But in the interest of being cheap, I would check the filters first as Joe also suggested. Is your fuel pump new also? A weak pump will cause the same result. Should be easy enough to turn the engine over (ignition disconnected) and confirm you have decent flow. Another free check. If it seems ok, you may find the 5/16 line is the issue...which may lead to finding out that your 'good' pump won't flow very well with the larger line. It's called the snowball effect...lol
Your timing sounds fine also, as does your plug gap.
Ratbird
« Reply #7 on: May 05, 2014, 01:39:58 PM »
Aw, yes, Autolite 45's is what they are - thx Lenz.
Thx Joe, I put a new tank in it a couple of years ago, and I always keep the tank mostly full. I should have replaced the cruddy old lines - that's getting done whether it's the problem or not.
Thx for the answers and suggestions CJShaker. I actually replaced the coil a couple of months ago. I had a stock one and someone told me to get the correct 40,000 volt one from Petronix so I did. BTW, if anyone wants a brand new "Flamethrower 45,000 volts" I have an extra one you can have cheap. I ordered the wrong one the first time and just kept it. Everything on the car has less than 1,000 miles on it. The air filter is a new K&N.
I made notes on every run, and I'm keeping them to review and update each time I take it to the track. It's mostly just a street car for fun, but I think I may have caught the "drag bug" cuz I'm already wanting to fix a few things and go back to make at least one good run.
Dave
pure fun
bn69stang
« Reply #8 on: May 05, 2014, 03:24:08 PM »
Congrats Dave get the bugs worked out and the next trip will be even more fun , and sometime this summer we will meet up there and run our cars .. I m excited to get my car there soon and see what the 434 inch 28 will do .. It s addicting huh ? .. But glad you had fun and it was a safe outing .. Bud
« Reply #9 on: May 05, 2014, 03:55:19 PM »
I hope you realize that, just like malaria, once you get the 'drag' bug you'll have it, in some form, for the rest of your life! ;)
fastback 427
« Reply #10 on: May 05, 2014, 09:59:54 PM »
Glad you had fun Ratbird!  Nothing like rowin  through the gears with a toploader and an fe 8) What was your 60 ft and MPH? MPH is the true test of HP and when you tackle the few issues you have watch that. Seems like fuel to me too, but don't rule out what the others have said too. Lots of new parts have been bad from the get go. Good luck and keep us posted!
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Ratbird
« Reply #11 on: May 06, 2014, 12:45:20 PM »
I'll try to get the 60ft and mph numbers up here tonight. The first two or 3 runs I was way too fast on the clutch and spun em' so those will be slow. On all but the first run I had the stumbling motor, usually in 3rd gear, although once it happened right at the end of first and even into second. I actually finished one pass in 3rd gear at 6000 rpm. That was a bad idea cuz for the last couple hundred feet I wasn't gaining any real speed.
The good is that I never missed a gear, and I was power shifting all the way. And if you could feel my mechanical clutch pedal you understand what an accomplishment that was. Right after I got my new motor and clutch setup my Z-bar actually cracked a weld so I had to reinforce it.
3 pedals may not be as fast, but they're a blast!
Anyway, back to work.
pure fun
Ratbird
« Reply #12 on: May 08, 2014, 12:48:47 PM »
Dang, I can't find my time slips anywhere. They'll show up sooner or later.
I did put the speeds, ET's, and reaction times into a document for future reference. My top speed was anywhere from 90- 94mph.
Can you guys recommend what type fuel line to use? I prefer something that is easy to work with. I know my local Autozone loans out brake line flaming tools. I'm pretty sure they'll have the same for fuel lines.
Thx, Dave J
pure fun
bn69stang
« Reply #13 on: May 10, 2014, 09:39:31 PM »
Dave you should run 3/8 inch line from tank to carb , and get a 3/8 inch pick up as well along with the same filter . I ve been down that road already .. All big block car s came 3/8 inch line .. Bud
drdano
« Reply #14 on: May 11, 2014, 03:43:47 PM »
Dave, what track are you running at?  I had the exact same symptoms at Bandimere last year and turns out it was running out of fuel.  Acts just like the ignition was cutting out the same way you describe.  I didn't fully verify the problem until I got a run out on the road recorded with my AFR computer feeding the fuel pressure in that I could see when the RPMs fell on their face the fuel pressure was dropping quick.  http://fepower.net/simplemachinesforum/index.php?topic=1297.msg14936#msg14936
As others have stated, thats what I'd look at first...that 5/16" OEM fuel line is probably the culprit.
