Author Topic: Power by Ford Chrome Valve Cover baffles  (Read 5177 times)
2VNTG68S
« on: April 21, 2014, 07:10:14 PM »
Hit my roller rocker shafts.  Any issues with removing the baffles? I think they should clear if I take the baffles out but want to make sure I'm not screwing something up by doing so.
garyv
Re: Power by Ford Chrome Valve Cover baffles
« Reply #1 on: April 21, 2014, 07:47:46 PM »
Have you tried using 2 gaskets to see if that will give you enough clearance?
Might be worth a try.
garyv
2VNTG68S
« Reply #2 on: April 21, 2014, 08:27:42 PM »
No, its not even close.  The covers can't even be bolted down to check rocker clearance.  Another gasket won't help and I doubt a spacer would either.
« Reply #3 on: April 21, 2014, 08:39:26 PM »
You can cut the baff's out, the only issue will be if you have a lot
of oil in the cover it may and most likely spit some out the hole.
If you are running a late model style PCV system it may suck oil up also.
Depending on the rocker system the small PBF covers may not clear even with the baff's  cut up.
bartlett
« Reply #4 on: April 22, 2014, 03:20:14 AM »
I cut my baffles out of mine to clear rockers... works great no problems ....
