Author Topic: aluminum head for 390  (Read 7715 times)
Jim Comet
« on: April 20, 2014, 08:34:52 PM »
Does anyone make an aluminum head for a 390 with 58-64 cc combustion chambers? I am considering a move to aluminum but am afraid if I went with an Edelbrock or Felony head with 72-76 chambers the drop in my compression would almost negate any performance gains. My current heads are C8AE-H heads with CJ valves, milled to 58cc chambers and showed to flow 230 intake and 180 exhaust on the flowbench. I would like a head where I could use my Comp rockers and Harland Sharp stock style shafts. The closer to $2000.00 I could stay the better. I am running an Erson solid cam with .595 lift and 242-246 duration at .050. MY intake is a port matched RPM with an 850 dbl pumper. This is a mild bracket car with a 3400 stall and 4.30 rear gears. It runs low 12's but I am hoping to get into the high 11's. Can a set of pro ports be done for 2500.00? Do the Blue Thunder medium risers with the quench chambers use stock type rockers? Can the Felony's be milled closer to 64cc? Can I trust a set of Doves Canadian CJ heads to not need work to function properly? I know for the same money I could almost build a stroker but for now I would like the heads and possibly upgrade the short block sometime down the road. Thanks for your opinions. Jim
Re: aluminum head for 390
« Reply #1 on: April 20, 2014, 09:12:10 PM »
Typically milling .0065-.007" will reduce the volume .1cc.  You would need to mill the Edelbrock head ~.060" to get to the 64cc volume.  It is not recommended to mill them more than about that amount.  They will begin to move around because of thinness of deck if you go too much.  I know some folks do it, and get away with it, but in the past many folks have had valve jobs go away quickly with milling more than .080".  Joe-JDC.
« Last Edit: April 20, 2014, 09:15:02 PM by Joe-JDC »
fe66comet
« Reply #2 on: April 21, 2014, 02:46:19 AM »
A copper .010 head gasket would get you closer.
CaptCobrajet
« Reply #3 on: April 21, 2014, 03:10:04 AM »
According to my buret, it takes about .0058 of an inch per 1 cc on an Edelbrock 6005 or any chamber with similar deck area.  The MR/HR/TP chamber and the 6008 Edelbrock have a larger surface area and are .0053 per cc.   I have to do careful cc work on heads with class rules and those numbers are exact.  Milling most FE heads .060 will change the volume by about 10 cc's.
You can't quite do the Pro Ports for $2500.  I'm not sure, but I think Barry's heads are in that range.  It costs some more to go Pro Ports, so a guy would have to weigh his options.   The Street Pro Ports that I do would be at least 90 cfm better on the intake, and at least 50 cfm better exhaust than what you posted.  That would be worth huge gains.  There is a post below where Barry listed some of  the numbers on his as cast heads also.  The Survival head "as cast" would appear to be a significant improvement with no porting, over what you have.  A person does not want to go too big on port volume at the 400 cube mark, so you should consider the cost, flow, and port volume in your weighing of the options.  It seems to me that a four tier system has been forming as far as aftermarket aluminium heads are concerned.  First there are the "out of the box Eds, then Barry's "out of the box" heads, then some CNC options like Craft and Barry sell, as well as my Street/Strip Pro Port, and then the high end stuff that requires big bores, manifold mods, and offset rockers.  There are variations within those four categories, and different ways to prep them all for the task, but basically there are four food groups of ways to go about it......a very general and basic guide, and the costs will go up as you work through the range...........the Ed being the least expensive, and the "high end" all-out stuff being the most expensive.  It is also important to do something that is a "fit" for your combo and your intended purpose.  A person wouldn't want to drag race with a sway bar, or road race without one.........kinda the same with engine parts, but harder to explain quickly.
Blair Patrick
bluef100fe
« Reply #4 on: April 21, 2014, 10:18:05 AM »
Not to take away from anybody's aftermarket heads but if your c8 heads are in good shape and haven't been worked over a bunch there is more than enough power to be had with those heads to get you into the 11's if your car is setup better or similar to my truck... My truck has broke into the 11's at 3850 lbs. with the same heads your using and a factory intake... You have more compression than me but I have more cam... if your budget won't allow for the better aluminum heads... IMO a box stock set of aluminum edelbrock performer rpm heads will cost you a bunch of compression and might not get you where you want to be without some extra work...  Which then leaves you too felony,bbm, stage x edelbrock, blue thunder which take special rocker stands, or Blair's street strip pro ports which I don't know which rockers we can use on them maybe stock configuration stuff will work....I want a set of Blair's heads to replace my c8-H Heads. But I think they are more than $3000 depending what options you want... I still think they are a good value hence why I want a set lol..
I guess what I'm saying is if your only after a tenth or three you could probably get there with some port work on your current heads... And not blow your budget... Good luck
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
