Author Topic: '65 427 and c6 trans deal of a lifetime $5000  (Read 5786 times)
Ididntdoit
« on: April 08, 2014, 08:50:45 AM »
SEE UPDATE BELOWI'ts a 1965 top oiler - it has the 4-bolt mounts - The block was blueprinted on cnc equipment by R.A.D. in palmer, MA (check them out on the web) and yes, they are experienced with FEs.  I just picked up the completed short block last month.  The block has 8 sleeves but has never been damaged (it was .060 when I got it) they did not go into water when they sleeved it.  The water jackets have no corrosion.  the bore is 4.25.  it has a cast, non grooved crank that is .010/.010 and has been indexed and the strokes matched.  the rods are C7AE-B magnafluxed with ARP 3/8 bolts.  The pistons and rings are off the shelf wiseco flat tops (.016 in the hole) - The assembly has been ballanced. As mentioned, the short block was also professionally assembled - Its ready for your top end, valvetrain, and oiling system.
I'm pricing it at $3500 - thats right, for the cost of an unmachined aftermarket block you can have this professionally assembled complete short block (I have almost that much into the machine shop bill) I do not want to ship this, but will work with you if you want it - I may even be willing to meet up at or near the FE race & reunion.  I also have a set of done CJ heads and a PI intake that I will sell at a great price either with the shortblock or after the shortblock sells.
« Last Edit: September 05, 2014, 11:20:32 AM by Ididntdoit »
Re: '65 427 short block
« Reply #1 on: April 08, 2014, 07:50:01 PM »
crap.
Everytime I wanna buy something, I've already spent all my money :P
good luck!
Ididntdoit
Re: '65 427 and c6 trans deal of a lifetime
« Reply #2 on: September 05, 2014, 11:19:36 AM »
This is again available - my project never materialized - the cj heads are now on it along with the PI intake - It has a general kinetics solid with factory adjustible rockers/pushrods - the trans is a fresh dynamic manual c6 with one of their 10" converters......the first person that shows up with a truck and 5k cash can have it.....I have all the recipts for the motor and trans....package only, come and get it
