Author Topic: Large lot of FE parts incl Tripower & Service block - added parts  (Read 4245 times)
babybolt
Pictures are here:
https://picasaweb.google.com/109047749994930397528/Fepartlot?authuser=0&authkey=Gv1sRgCO-9ooKdkdOI8AE&feat=directlink
Whole lot for $1100.  Won't separate parts.  Western PA.
In no particular order:
SX thick wall 361 short block, standard bore. Rebuilt.  With truck pan.  This has the FT forged crank.
Nice TriPower intake, has one small hole drilled in the side near the back.
Original TriPower aircleaner
2 set hydraulic rockers
Lifter valley baffle
Starter
Damper
Truck oil pickup
1 Steel shim head gasket for mockup
22 rods, all with pistons
Lots of head bolts, cleaned
8 pulleys
3 timing chains, decent used
2 very good early breather caps
Brackets
Original marine oil cooler adapter
PCV setup
rod bearings 0.020
CJ oil filter adapter
Breather basket
2 spare timing pointers
Oil slinger
Crank bolt
2 timing chain retainers
C3AF-AH mint distributor, little bit of rust on cam, fits 63 390 PI and others
C3SF-D distributor for parts
Large thermostat cover, mint & two thermostats
Nos HiPo valve spring retainers
Bunch of pushrods
Crank spacer
Very clean front cover
Engine mounts
2 takeout oil pumps
Oil pump pickup tube
Two distributor hold downs
Heavy duty service fuel filter – frame mount
Breather cap, only for the rubber grommet and plastic right angle nipple
Two fuel pump eccentrics, fair condition
Three distributor hold downs
Early 60 or 61 distributor core 352 manual trans, has Motorcraft points plate
Original Ford steel fuel pump block off plate
Two later small thermostat covers, some pitting on the early one, later housing with emission port has undecipherable date code
Three cam plates, two early style with the short grooves front and back, and one later plate
PCV adapter with PCV
Heater hose fitting
Fuel canister bracket that hangs the canister off of the fuel pump boss
Block plate
Also today found a passenger car oil pan.
Picture added of one set of rods.
Added new Dove aluminum front cover with mounting bosses
Added two pulleys - one is a single groove water pump pulley, probably 427 (and Y-block).
Added two more block plates
Couple of comments: this is the third tripower intake I've bought, it took buying three to find one good one.  The shortblock is a rebuilt 361 FT block with the big forged crank.  It has a cam and lifters.  Found a dent in the pan today.
Added another set of NOS HiPo retainers and another single groove crank pulley, pictures pending.
Added CJ thermostat housing with 68 date code, needs a spot of weld
« Last Edit: April 20, 2014, 08:54:44 AM by babybolt »
