Author Topic: NIB Blue Thunder 2x4 intake, factory C3 aluminum 375hp/390 intake. (Both Sold)  (Read 6043 times)
Selling off a few things to help fund the changes I'm making to my Mach 1. Shipping charges will be on top of the posted prices. I'll answer any questions, but the first "I'll take it" to post here will get a hold put on it until I receive payment. I prefer USPS Money Orders or bank checks but will accept a personal check....however, if you're a "newbie" here or somebody I don't recognize, I will wait 1 week for the check to clear. I hope you understand.
First, a brand new, still sealed in the plastic Blue Thunder 2x4 Medium Riser intake. It has never been removed from the plastic, and I wasn't going to cut it open to take pictures. Known for their extremely high casting and machining quality, Blue Thunder is the best. This one is perfect, no surface corrosion or anything. Still like new and often hard to find due to limited low production runs. In fact I don't believe anybody has been able to sell them for some time due to this. $600 plus shipping. (Sold to Barry R, pending payment)
Also for sale, a factory C3 aluminum intake I believe is for a '63 375hp/390. This one has been painted by the previous owner, so it would require a bead blasting or shot blasting to make bare aluminum again. NO stripped threads or issues to be seen. Very little corrosion around water ports. Much better than most I've seen. Heat shield is in place and underside is very clean. The intake was cleaned before it's prior use. Has carb studs and a chrome vent tube and cap which I'll leave on. Has some light impressions around intake bolt holes from washers, but that is the way they came from the factory from my experience. The front water bypass tube is useable, but in my opinion should be replaced with a brass unit for security and peace of mind. No other issues at all that I can see. $250 plus shipping.
« Last Edit: April 08, 2014, 08:54:27 PM by cjshaker »
Prices dropped to $600 and $250 respectively. Any lower and I will just keep them.
Doug
I'll take that intake - - need it for a customer's project.
Barry, it's yours. According to the UPS Shipping Calculator, shipping should be $30. You should have my address, so you can mail me a check or I can bring it up when I pick up my stuff to save you shipping. It's up to you.
