Author Topic: 10-30wt vr1  (Read 4507 times)
Saltshaker
10-30wt vr1
« on: March 24, 2014, 06:37:44 AM »
Is it ok to use 20-30vr1 in a 428 factory crank and rods?
Jon
Re: 10-30wt vr1
« Reply #1 on: March 24, 2014, 08:32:56 AM »
It'll be fine. Some good stuff below and I'm NOT that Bob  ;D
http://www.bobistheoilguy.com/motor-oil-101/
« Last Edit: March 24, 2014, 08:36:37 AM by machoneman »
fe66comet
Re: 10-30wt vr1
« Reply #2 on: March 25, 2014, 12:43:40 PM »
10-30 in a good quality will work fine in a stock engine or even slightly modified. If the temperature rises above 80 degrees I switch to 10-40. Do not use oil that has there starburst logo on the container, the oil contains additives to prevent proper flow to the components in the combustion. I like the Royal Purple or Red Line street oils personally.
