Author Topic: Autolite C8AF-AC Carburator  (Read 6805 times)
chris401
« on: February 13, 2014, 08:12:27 PM »
It has 1.42 primaries 1.55 secondarys. Is this an emissions carb? Anyone know the cfm? I am guessing around 650 to 675.
Thanks
bsprowl
    • Ford FE Information
Re: Autolite C8AF-AC Carburator
« Reply #1 on: February 13, 2014, 09:25:32 PM »
My '68 shop manual doesn't include it but it has two others with similar throttle bores that flow 446 CFM.
chris401
« Reply #2 on: February 13, 2014, 09:30:41 PM »
The smaller ones are what I really want but this man is wanting to trade some parts I wont use anytime soon.
Thanks
chris401
« Reply #3 on: February 13, 2014, 09:38:11 PM »
Copied from the Mustangtek site. What does open emissions mean? Either?
Full link= http://www.mustangtek.com/4300/4300.html
C8AF-AC
Unconfirmed Application. Information may or may not be complete or accurate68 390 Ford, Thunderbird (w/AT, open emission)
Unconfirmed Application. Information may or may not be complete or accurate68 428 Ford(exc/PC) (w/AT, open emission)
4v
Auto
Ford Service Part Number ID C8AF-9510-AT
« Reply #4 on: February 13, 2014, 09:50:47 PM »
If your post over on Ed's forum draws a blank, try VMF:
http://forums.vintage-mustang.com/concours-forum/601653-autolite-1100-decoding.html
chris401
« Reply #5 on: February 13, 2014, 10:34:51 PM »
Thanks for the guides. The looks like the AC means automatic for 68 390 and non cj 428. Is "open emissions" the PVC hose port in the back of carb?
« Reply #6 on: February 14, 2014, 09:17:43 AM »
CFM data here:
http://classicinlines.com/autolitecarbs.asp
http://mustangtimes.net/33-4/pg52-54.pdf
Not sure what the open emissions really means.
« Last Edit: February 14, 2014, 09:21:00 AM by machoneman »
« Reply #7 on: February 14, 2014, 09:30:22 AM »
Found it! Oddly, it's also from MustangTek's database of PDF'ed documents.
http://www.mustangtek.com/Library6/PDF/ShopTips6-1.pdf
It seems "open" is pre-Thermactor air pump or merely a simple open breather and a PCV system. Closed = Thermactor, air pump, later an EGR valve, etc. Is that how you read it?
« Last Edit: February 14, 2014, 11:42:29 AM by machoneman »
chris401
« Reply #8 on: February 15, 2014, 10:03:36 AM »
I understood open emission the same. Thanks for the info Bob. I also saw a link on fordfe dot com. Cant post link from phone, it said that this carb was a 650. Givin the venturie sizes that makes sense as Holley 750 has 1.72's.
Corrected CFM
« Last Edit: February 17, 2014, 11:16:05 AM by chris401 »
