Author Topic: Engine masters on FE Power forum who have done EFI Conversion  (Read 20922 times)
Bad Byrd
« on: February 13, 2014, 07:37:09 AM »
So every now and again I just get a real good nights sleep and I wake up with what I think is a real good idea. My history with building cars and bikes goes back 30 yrs, however the majority of that time is mainly over the last 15 with higher HP technology stuff. I have decided to ditch this carb stuff and and run a FAST EZ-EFI system.
Now my question is to you Engine builders with EFI conversions.
I have three options to choose from all based off of intakes I already own, I am not looking for the max HP, but a combo of HP, Original looking old school motor and drive ability. My combination is as follows:
1) Bored and stroked cross Bolt main 406 so CI is 445
2) Lentech AOD
3) Rear end gear is a 3.89
4) Car weight is about 3900 lbs wet (1961 Thunderbird)
Intakes available
1) Ford LR 1963 Dual Quad ( Thinking FAST EZ with dual quad upgrade Kit )
2) Shelby Side winder
3) Edelbrock Street Master
All three intakes have plus or minuses I am sure, the one that intrigues me the most is the dual quad with the FAST EZ, however I have read on this forum some short comings on the EZ system and I have also read the EZ 2.0 is a better system................I sure like the looks and the function of the 2.0 better so the right fit might very well be the Street Master or the Shelby which I know most here dont really like that intake for performance.
So what to do? I will be interested in hearing your thoughts, One thing is for sure................I have made up my mind and the carb really needs to go away.................Hell Its been so long I cant even remember how to tune on of those things!!! LOL
« Last Edit: February 13, 2014, 07:50:52 AM by Bad Byrd »
Re: Engine masters on FE Power forum who have done EFI Conversion
« Reply #1 on: February 13, 2014, 08:23:24 AM »
Any of those intakes will support the horsepower levels that you will be making with that engine, assuming they are in the 425-475 HP range.  I'll bet if you compared them on the dyno they'd all be within 10 HP of each other.  On the 2X4 intake, you may have a fit problem; on the factory 3X2 Thunderbird intakes, the carb pads were flat rather than angled, and I believe that this was for clearance issues to the cowl or the hood.  Your 2X4 intake has the angled carb pads, so that could pose a problem.
If it was me, and the fit problems could be resolved, I'd run the 2X4 intake, just because it looks period correct and 2X4 setups are just cool in general.  Otherwise I'd run the Streetmaster.
Bad Byrd
« Reply #2 on: February 13, 2014, 08:38:12 AM »
Hey Jay
The clearance isnt an issue at all, the Hood has been modified with a 4" Cowl hood scoop. the Angle issues is easily overcome with a Phenolic Machined spacer to get them flat and on plane I have done 3D cad drawings in inventor already to fix that issue if I used it.
The motor better produce more then 475HP, I have a lot of $ wrapped up in the porting of those factory heads, Callies Ultra rods, and stroker crank to see only 475. I might very well be asking too much from this old motor, but I dont have nearly the flow numbers out of the wifes 427 SBC and it throws down 400 to the tire behind a TH400. We will see though!
I am intrigued as well by the dual Quad set-up but no way to run the 2.0 version I would have to see if I can fit the original style system on there to make it fit. I would be very cool though! I do like the looks of the street master best out of the singles.............It just needs some serious work to get it to the porting level I have already done to the Shelby!
Thanx for the opinion I appreciate it!
« Reply #3 on: February 13, 2014, 09:29:59 AM »
If you are running more than 475 HP, I'd really recommend going with a different intake; all three of them will be horsepower limiting over 500 HP or so.  Maybe a medium riser 2X4 intake, or a Performer RPM?  How much power do you expect to make with that engine?
Bad Byrd
« Reply #4 on: February 13, 2014, 10:22:41 AM »
You know Jay I really don't know what to expect, I am so used to pulling big numbers from a Mod motor these old school builds just boggle my mind. The goal was to see 500hp to 525hp..................Which is so disappointing for the $ spent. I could have built a 800 HP mod motor for what it cost to build this motor. But at the end of the day it all comes down to drivability which the limiting factor with Higher HP old technology and a street car.
When you come from having a low 10 second daily driven 5000 lb truck to a 4000 lb old school FE that will be lucky to run with a Bone stock Subaru STI the whole thought is kind of depressing when you truly think about it. But it is what it is, and I know what I am dealing with.
« Reply #5 on: February 13, 2014, 01:07:00 PM »
BByrd, a couple of thoughts.
First, if you insist on the use of components that were designed back in the sixties, you should expect to get '60s numbers from the dyno. New-design heads, with their greater combustion-chamber efficiency, coupled with the new runner profiles that then become available, will give a significant numbers boost. Particularly if you use the flow studies you do as the basis for your camshaft design. You need to start with a 21st Century perspective.
I have done a number of EFI conversions on FEs. Working with the Holley development people, I did the first dual-throttle-body installation on a MR 427, back when EFI conversions were just becoming available. On a street '67 Mustang, the Holley dual throttle bodies were good for almost two seconds reduction from 1500 to 6000 in second gear. That's over ANY pair of carbs. The project resulted in an ongoing series of articles I wrote for Super Ford Magazine. I'll never use a carburetor again.
« Reply #6 on: February 13, 2014, 04:57:55 PM »
Weren't those mod motors supercharged or turbocharged?  That's a whole different animal, of course.  My supercharged FE made 1030 HP on the dyno, on 17 pounds of boost.  If you are looking for big power numbers why don't you consider a turbo or a blower?
Bad Byrd
« Reply #7 on: February 13, 2014, 07:50:46 PM »
Hey Jay
Not really looking for big numbers on this particular project, just making a general statement about the lack of HP per cubic dollar spent. Running a Supercharger on a FE and make it run on 93 isn't what I would call very reliable unless you willing to fork out $40K to $50K and I might as well put a Proline BBC in it and stomp the FE's guts out. This is probably why I am such a mod motor fan.....................For $25K I am dancing with 900 to 1000 HP motor and trans and driving it to work every day!
No I am good where I am at, I just need to ditch the whole carb thing, run the Fast 2.0 and call it good. It surely isn't going to win me any titles in the 1/4 mile...............But with the set-up I have I will surely stomp a civic or two! LOL
LuxurySportCoupe
« Reply #8 on: February 14, 2014, 06:32:37 PM »
Hey Jay
Right around the 500-600 hp level, mod motors are actually more expensive to build than an FE. Not only do you have to buy the forged internals, etc, you have to buy the boost on top of that; were an FE will do it naturally aspirated. Or for less money than a mod motor or an FE, build a  boosted 460 based stroker and shoot for 1500hp on pump, but that wouldn't be as cool or different as an FE.
1964 Galaxie 390 cruise-o-matic. 445 and C6 coming soon.
67 Fastback
« Reply #9 on: February 14, 2014, 10:06:12 PM »
I have had a Fast 2 system on my 433 FE with Tri Power fuel injection , it has been  up and running for 5 months it has been faultless . No doubt it is not a cheap setup to start with but the overall look is very impressive and the driving of it is bloody unreal . Very smooth in its operation and delivers the goods at WOT .
Cyclone03
« Reply #10 on: February 15, 2014, 12:28:25 PM »
I have an ez2.0 on my 433ci FE,also nearing 5 months and it to is flawless. Its on an RPM with a 1" open spacer.
The timing control sold me on it,as well as the 8 injectors in the TB.
All my plugs look the same so distribution seems to be good.
Lance H
drdano
« Reply #11 on: February 18, 2014, 04:08:49 PM »
I love comparing apples to bowls of petunias falling from the sky!   ;D
Here's an FE powered vehicle that went 400mph.  Naturally aspirated*!
*One motor naturally aspirated.  One not so much.  Your mileage may vary.  Do not taunt Happy Fun Ball.
« Last Edit: February 18, 2014, 04:21:38 PM by drdano »
LuxurySportCoupe
« Reply #12 on: February 18, 2014, 08:11:34 PM »
^ Now THAT is cool! 8)
Faron
« Reply #13 on: February 19, 2014, 12:21:10 AM »
I guess My 550-600HP 390 that runs on 92-93 Pump is unfeasible  :P, It was built for less than 6000.00 ( in 1996 ) ran great for 14 years ( refreshing now ) I agree with the above posts Old Tech Gets You Old Numbers , and even the best Parts may not perform depending on the combo , Sometimes it aint the Ingredients , its " the Cook" , I built a 390 with a 671 blower because then ( and even more so now , 427, blocks are still More than the Blower Kit was ( same deal back  in 1986) I am sorry the Gentleman had a disappointing ) outcome on his FE , but not all have   8)
Faron
« Reply #14 on: February 19, 2014, 11:27:28 AM »
Not Insulted or any of that , How is the Dist working for you ? its hard to know who is posting by log in names  :o, I hope you did not take offense to anything I posted , I like all Fords Mod 5.0 FE etc , good luck with your projects
