Author Topic: Blue thunder 427 MR intake thermostat size?  (Read 8016 times)
selash
« on: January 29, 2014, 06:11:13 PM »
I just ordered a blue thunder 427 MR intake and was wondering what size thermostat it calls for?
I currently have the iron 4V intake on my 63 galaxie and it uses the large thermostat housing.
Will this work on my new intake?
Thanks in advance!
Re: Blue thunder 427 MR intake thermostat size?
« Reply #1 on: January 29, 2014, 06:54:59 PM »
small hole...
selash
« Reply #2 on: January 29, 2014, 09:30:32 PM »
Thanks.
I read somewhere that I can still bolt my large thermostat housing with the large thermostat to it?
Is that true?
« Reply #3 on: January 29, 2014, 10:06:11 PM »
I believe that that is true - although I've not done so.
« Reply #4 on: January 29, 2014, 10:07:43 PM »
I never tried it, but the local Autozone, O'Reilly's, you name it, sell the right one
Look it up for a 73 Ford F100 with a 360
8 bucks and you don't even have to clean it :)
http://www.autozone.com/autozone/parts/Compressor-Works-Water-Outlet/1973-Ford-F100-1-2-ton-P-U-2WD/_/N-ip844Z93xm0?itemIdentifier=141762_0_0_
428GT500
« Reply #5 on: January 30, 2014, 11:03:50 AM »
Small thermostat, 66-up type.
                                         -Keith
selash
« Reply #6 on: January 30, 2014, 01:40:47 PM »
Thanks,
I ordered one for a 67 mustang with a 390.
Had a GTA as my first car.  Did not enjoy changing the plugs, but loved the car.
Wish I still had that car. :-(
Jackal
« Reply #7 on: December 11, 2016, 10:27:18 AM »
I just picked up a 60-63 style Flowkooler water pump, $35 Robertshaw 180 deg t-stat, a Champion 3-row, and their aluminum surge tank for my 63.5 390. I am thinking about ordering a BT 427MR 4V intake for it. It sounds like I will need to exchange the t-stat for a different vehicle / size? Whats this about being able to use the larger stock size?
« Reply #8 on: December 11, 2016, 12:29:36 PM »
With the stock surge tank, I was able to use the small thermostat with a BT intake that has the small hole.
Required a little rtv to keep the thermostat glued to the surge tank, I let it set up a little prior to install.  No issues.
Jackal
« Reply #9 on: December 11, 2016, 03:00:39 PM »
Thanks Drew, maybe 427 surge tanks were different than 390 surge tanks? Guess we'll see which size the Champion surge tank is when it arrives.
I forgot that I had a Stant SuperStat on the shelf for the stock application and it is MUCH larger diameter than the Robertshaw, so I probably have what I need for the 427MR. I'd have been screwed on the cast iron intake though.
