Author Topic: Dip Stick Oil Pan Match And Identification; More Pictures Added  (Read 9409 times)
chris401
« on: January 26, 2014, 09:17:38 AM »
Lots of inconsistent info I'm finding online. I have a C7AE-6750-A Ford dipstick and tube. What oil pan does this match, how where do I find oil pan identification numbers and does it match a 6qt pan?
Photos are compared to blue, I believe a 66 F100 tube/dipstick and white being the C7AE-6750-A at bottom.
Thanks
PS: Not asking how to verify correct level with stick.
« Last Edit: February 01, 2014, 02:49:21 PM by chris401 »
chris401
Re: Dip Stick Oil Pan Match And Identification
« Reply #1 on: January 31, 2014, 03:59:28 PM »
Anyone?
fastback 427
« Reply #2 on: January 31, 2014, 04:49:29 PM »
Chris, the blue tube looks identical to the one on my 76 f350. The white one looks like the one on my 67 gta fairlane and the numbers are the same as yours.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
chris401
« Reply #3 on: February 01, 2014, 02:14:07 PM »
Does your oil pan look like this one? I noticed the hump in rear was more prominent than on my truck pan.
fastback 427
Re: Dip Stick Oil Pan Match And Identification; More Pictures Added
« Reply #4 on: February 01, 2014, 06:27:42 PM »
No it doesn't. I haven't seen that style yet. How deep is that from flange to bottom? Looks like its a 6 quart from earlier pickup.
Jaime
top end toploader
chris401
« Reply #5 on: February 01, 2014, 06:39:05 PM »
The measurements:
front to back= 10"
side to side=7 3/4"
deep= 6"
My early, 1965+, truck pans are all rear drain like in the 70's. This is the only pan I have ever had that drained at the corner. I have had a 64 solid lifter engine, 66 410, couple of Galaxie 390's and a 68 wagon 390. Think pan came from any of these engines?
Link: http://www.network54.com/Forum/74182/message/1390877725/Two+1965+Ford+Trucks%2C+Full+History%2C+39+Years+Old
« Last Edit: February 01, 2014, 06:42:44 PM by chris401 »
fastback 427
« Reply #6 on: February 02, 2014, 12:18:41 PM »
I'm at a loss on your pan. There should be a number stamped into the pan somewhere. Hit it with a scotchbrite pad and check closer maybe?
Jaime
top end toploader
chris401
Numbers Location?
« Reply #7 on: February 03, 2014, 04:09:50 PM »
I was going to paint this pan and found it needed more work. Ill glass blast it again. What area do I look for identification, part or casting number?
fastback 427
« Reply #8 on: February 03, 2014, 06:04:26 PM »
Should be in the rear of the pan. Might be easier to see from the inside. If your gonna glass bead the pan make sure to scrub the heck out a it. Did the same on an aluminum intake years ago and played hell cleaning it up on the inside!
Also check the center under the pickup as I've seen them both.
« Last Edit: February 03, 2014, 06:19:16 PM by fastback 427 »
Jaime
top end toploader
chris401
« Reply #9 on: February 03, 2014, 06:31:14 PM »
Ill do that and post back. Here are a couple photos of my truck pan (1974+/-) with fresh paint.
fastback 427
« Reply #10 on: February 03, 2014, 06:47:53 PM »
Looks good! What color and brand paint did you use?
Jaime
top end toploader
chris401
« Reply #11 on: February 04, 2014, 09:06:55 AM »
Thanks. Dupl-Color DE1606
