Author Topic: FE crankshafts  (Read 5127 times)
fomocoloco
FE crankshafts
« on: January 21, 2014, 01:25:06 PM »
i have 5 428 crankshafts and 2 forged 391 crankshafts for sale. 3 of the 428 cranks are std/std $400.1 is 10/10 $350.1 is 20/20 $300. 1 of the steel cranks has already been machined to fit the FE. the other still has the large snout and has never been touched. i can have these checked and turned if necessary prior to sale. also have a pair of early 58 edc heads with the machined chambers and plugs on the end of the heads $200. 11 68 oil filter adaptors $40 each.. a quantity of cam thrust plates, oil slingers, crank spacers, and fuel pump eccentrics. around 30 FE blocks etc. blocks are priced from $250 up depending on date code and casting #. they are all clean and ran thru the hot tank. the 428 crankshafts are priced from $300 up and I want to gauge interest prior to taking them to the machine shop.the c6te $ sign 391 steel crank is std/std  $300. the 72 391 steel crank is $150.
jim Oberg
Eudora ks
7855422500
« Last Edit: January 21, 2014, 03:29:58 PM by fomocoloco »
8 65-72  f100 sb trucks 5 428's 1 460 2 521 strokers
1 66 f100 lb ranger sold
3 67-75 f350
numerous parts vehicles and parts
88 tbird 482ci 427 stroker 6R80 project
Re: FE crankshafts
« Reply #1 on: January 21, 2014, 01:40:13 PM »
Prices?
