Author Topic: FE Build at Hot Rod Engine Tech  (Read 22803 times)
rockittsled
  • 1976 F-250 390 4v C6
Re: FE Build at Hot Rod Engine Tech
« Reply #15 on: January 24, 2014, 01:32:13 AM »
hmmm, now it is saying my 2011 HP laptop has an unsupported Internet Explorer, 6 no less
http://hotrodenginetech.com/what-fe-combination-would-you-build/
LuxurySportCoupe
« Reply #16 on: January 24, 2014, 07:05:25 AM »
It did that to me too. If you get to the homepage, and click directly on the forum button at the top, then click on traditional hot rod engines, you can get there. I still can't seem to register though.
1964 Galaxie 390 cruise-o-matic. 445 and C6 coming soon.
KMcCullah
« Reply #17 on: January 25, 2014, 10:11:55 PM »
So I've been waiting since the 18th for an email to show up confirming my registration. I went to the login page and entered my email address and password. And checked the box "resend confirmation email." My confimation email came instantly.  :)
Kevin McCullah
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #18 on: January 26, 2014, 11:42:47 AM »
Still having that same problem and my Chrome is up to date. I can click on all the stories except the FE! Same crap comes up....
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #19 on: January 26, 2014, 01:01:30 PM »
That's weird.  I emailed John about this but haven't heard back.  Maybe problems like this are why there isn't a lot of action on his forum...
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #20 on: January 26, 2014, 01:06:01 PM »
  Thats part of the problem for sure Jay! LOL
Wes Adams FORD428CJ
64 Falcon 428FE
« Reply #21 on: January 30, 2014, 05:48:13 PM »
After waiting since this thread appeared here, I decided to push things today. I messed with it for a while and although I haven't gotten a 'welcoming' email to this moment, the site started recognizing me. So all is good, I guess.
rockittsled
« Reply #22 on: January 30, 2014, 08:19:45 PM »
Ok, I finally got on and posted my thoughts on an engine build up, would everybody post their thoughts on mine
Mine is a little different and here is why, I have a 76 F250 with a 390 4V and C6. I am an aircraft mech and sometimes gypsy around following the contracts. I need a truck that is dead-nuts reliable and starts every time with a tool box and other necessary sundries loaded in the bed or trailer or both up to 4 or 5 tons. It has to be powerful enough to cross country and efficient enough I wont have to work three or four months just to pay the gas bills. My thoughts start with a mirror 105 block and a possibly a 428 crank for 410 ci (I am thinking a 445 stroker inhaling 445 ci of air uses more fuel than a 416ci inhaling 416 ci of air, even at cruise). Using an Al head with modern combustion chamber characteristics for efficiency ( the FElony head sounds like it fits the bill) and a hyd roller cam with all necessary machine work on block and oiling sys as required. Compression ratio will need to match with induction choices as follows, a properly sized turbo blowing through an intercooler (the '99 era Powerstroke Diesel intercooler seems to fit the dentside radiator support according to members of the FTE Forum) into a bread box type upper (like the old Cartech) on a dual 4V manifold or Jay Browns 351C adapter with a tunnel ram under the bread box. Fuel to be supplied by injection using a 5.0 computer with a reprogramed MAF and supplied using the Edelbrock 3605 - Edelbrock E-Street EFI Systems (if compatible). To maintain streetability on street gas, use a Snow Performance water/meth injection kit If all of this plays well together, then I would slide an E4OD tranny behind that with a tank for the water/meth solution in a 7 or 8 gallon tank mounted behind the spare tire in the bed.
what do you think?
« Last Edit: January 31, 2014, 06:56:52 PM by rockittsled »
« Reply #23 on: January 30, 2014, 09:07:45 PM »
That sounds like a really cool build to me.  Would you be limiting the boost to something around 7-8 psi, or going all out?  I think if you limited the boost you could probably run without the Snow Performance setup.  Those things can go through a lot of the water/methanol mixture.  I had one on the supercharged engine in my Mach 1, and I ended up just disconnecting it and backing off the timing a little, to avoid continuously adding the "boost juice".
rockittsled
« Reply #24 on: January 30, 2014, 09:15:40 PM »
I think limiting the boost would be a good idea with the snow setup providing that little extra bit of protection at the upper ranges of the throttle position to boost ratio (if that sounds logical) when the truck is all loaded up
« Last Edit: January 31, 2014, 06:55:33 PM by rockittsled »
rockittsled
« Reply #25 on: January 30, 2014, 09:24:42 PM »
at a seat of the pants WAG, which intake setup do you think would provide a greater torque curve, the longer runners of the tunnel ram, or the dual 4V with maybe a phenolic spacer for the length? I do not know the size of the runners in either manifold to guess the velocity difference between the two
rockittsled
« Reply #26 on: February 08, 2014, 01:34:46 AM »
I just checked the thread over there to see if anyone from here or anywhere else has posted any more thoughts for a combo.  Still not a whole lot of traffic, apparently.
Also, I just finished reading to current on Jay's adapter and did not realize that Trick Flow has the 5.0 F.I. type intake for the Cleveland.  All those choices........WHAT NOW!?!  :o
