Author Topic: Bad Byrd Brakes  (Read 3991 times)
Bad Byrd
Bad Byrd Brakes
« on: December 23, 2013, 12:21:08 AM »
I have been working on the braking System for the Bad Byrd project and got the rears on, but now its on to the fronts. The rear set-up is a 13" Wilwood 4 piston caliper set-up and the front is a AeroSpace Brakes 14" with 4 piston Calipers and the GT Hub. Although Quite a bit different then the Brembo and Stop Tech kits I have done in the past these are equally well done. One little hick-up that appears to be my fault is the front Calipers where supposed to be Black and I didnt relay that to them...............So I might be sending those back!
