Author Topic: To much crankshaft end play  (Read 9294 times)
chris_r
« on: December 05, 2013, 09:44:53 PM »
I need some help. I am building a 428 so i drop in a new crank today and i have .010 end play. i have tried three sets of std. speed pro and two sets of std. F-M all had .010 end play
Re: To much crankshaft end play
« Reply #1 on: December 05, 2013, 10:03:57 PM »
If it's an automatic tranny, run it at .010 I say. Keep in mind that although the Ford spec is a max of .008, it's like Johnny Depp says in those Pirates of the Caribbean movies: they are just really guidelines! JMO.
chris_r
« Reply #2 on: December 05, 2013, 11:15:24 PM »
 it's a top loader 4 speed
DEANs427
« Reply #3 on: December 05, 2013, 11:28:41 PM »
Try king brgs, read articles in crankshaft brg question a few posts down
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
« Reply #4 on: December 05, 2013, 11:31:56 PM »
Beat me to it! yes, XR7 answered this same question only a few days ago. King has oversized flange thrust bearings.
http://kingbearings.com/maxflange_proflange.php
chris_r
« Reply #5 on: December 05, 2013, 11:38:52 PM »
thanks for the help i will check them out
« Reply #6 on: December 06, 2013, 06:58:17 AM »
I'd run it at .010.
Not far enough from "perfect" to cause me to lose any sleep on a thrust.
Make certain that you're getting a full measurement though - hate to have it actually be even more....
chris401
« Reply #7 on: December 06, 2013, 07:31:48 PM »
I have .009 with a steel flywheel. Chased down a ding at idle and found it to be flywheel pinging when crankshaft bumped bearing. NP435 65 F250 13,000 miles no issues.
« Reply #8 on: December 06, 2013, 07:32:56 PM »
And since it's a tad on the looser side, make sure you check the flywheel bolts interference with the back of the block. Sometimes they're close when you use aftermarket bolts and will hit the block. It's always a good idea to mock up the clutch/flywheel setup and make sure nothing is bottoming out or causing interference with the crank at full fore or aft movement....including the snout of the tranny against the pilot bearing or crank.
MeanGene
« Reply #9 on: December 07, 2013, 11:39:17 AM »
Better a little loose than a little tight, but make sure you actually only have .010- more than that and I would work on tightening it up
