Author Topic: 427 sohc balancer  (Read 6448 times)
1932fe
427 sohc balancer
« on: November 25, 2013, 04:59:45 PM »
Hi just wondering which balancer could I  use on the 427 sohc,
Will a romac Red series factory 427  work. If not what else are people using  Thanks
Re: 427 sohc balancer
« Reply #1 on: November 25, 2013, 07:16:43 PM »
Romac will work fine.
Tougher to find or make proper pulley for the crank...
1932fe
« Reply #2 on: November 26, 2013, 01:08:54 PM »
thanks for the reply Barry. The balancer comes with a pulley I was hoping to use it. Is the pulley not the correct diameter Thanks
« Reply #3 on: November 26, 2013, 08:45:40 PM »
Cammer pulley normally sticks out a lot further than normal.  '62 T-bird if I recall correctly.  We've made spacers to match up a "normal" pulley
1932fe
« Reply #4 on: November 27, 2013, 02:51:51 PM »
Thank you for the advice Barry
