Author Topic: FE in 65 Falcon  (Read 22947 times)
talladega
FE in 65 Falcon
« on: October 25, 2013, 10:29:46 AM »
Hi all
Have a chance to buy a 65 Falcon with a puked 302/C4 setup.  How big a deal to put a FE/C6 in?
Thanks
1969 Talladega 428CJ
Midstates Cobra replica 428CJ
427CO stroker on engine stand
Re: FE in 65 Falcon
« Reply #1 on: October 25, 2013, 12:21:19 PM »
I think the biggest issue will be the shock towers; they will have to be moved outboard to fit the FE.
Re: FE in 65 Falcon
« Reply #2 on: October 25, 2013, 02:02:54 PM »
If you research the work necessary to convert a '64 Fairlane to being a Thunderbolt, you'll have a pretty good idea regarding what'll have to be done. Detail differences for sure, but...
If you should decide to go forward with such a project. there are those of us who've done something similar and will be happy to offer 'tips'.
fastback 427
Re: FE in 65 Falcon
« Reply #3 on: October 25, 2013, 03:59:53 PM »
Crites has a complete kit for the swap including template to modify shock towers. Difficulty will depend on your skill and tools you have.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
NewFalconOwner
Re: FE in 65 Falcon
« Reply #4 on: October 25, 2013, 05:17:06 PM »
someone put one in his 65, heres his build if you can see it.. he choose to use a MII front end
http://www.tffn.net/phpBB3/viewtopic.php?t=24054
427Fastback
Re: FE in 65 Falcon
« Reply #5 on: October 26, 2013, 01:20:14 AM »
I recently acquired a 64 Falcon Futura 2dr sedan...Its a project the P/O bailed on..He did however put a Heidts front end in it...The resulting mods leave the engine bay big enough for anything you want...I don't have to feel bad about cutting the towers out.....I will be powering it with a nice little 70 351C 4spd that I have.....Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
talladega
Re: FE in 65 Falcon
« Reply #6 on: October 27, 2013, 08:30:08 PM »
Thanks for the replies.  After doing the research suggested here I just bought a 1969 Falcon roller.  Should make life a lot easier.  Thanks again.
Ford428CJ
  • FE FREAK!
    • Hillside Auto
Re: FE in 65 Falcon
« Reply #7 on: October 30, 2013, 08:27:40 PM »
Crites makes kits for the Falcon. You have to shave the shock towers with the kit... Here is a link for ya
http://www.critesperformanceparts.com/
Wes Adams FORD428CJ
64 Falcon 428FE
talladega
Re: FE in 65 Falcon
« Reply #8 on: November 01, 2013, 11:19:54 AM »
Actually I've found that '66 through '70 Falcon's engine compartments have same dimensions as Torinos; so this swap is bolt in.  Will post in members projects as things progress.
hyper64
Re: FE in 65 Falcon
« Reply #9 on: November 26, 2013, 10:09:01 PM »
Good move on going with the 1969 Falcon, I'm doing a 1967 and going to power it with a Blair Patrick 428/toploader combination. Not too many folks do this conversion but due to the fact that most Fairlane, Torino, Comet parts of that timeframe crossover you have lots of options.  I didn't touch the shocktowers as it fit fine during the mockup. I ordered one of Jay's intake adaptors and considering using it in this project. How about a tunnelram in there, I'm thinking that's the ticket.  There is an article floating around from the 70's titled "You Could Do This Swap in Your Sleep" concerning this process which includes Ford part numbers used in the swap. Jim M
MeanGene
Re: FE in 65 Falcon
« Reply #10 on: November 26, 2013, 11:21:00 PM »
Paul Mastro has a 454 stroker in his, with an MII front end- lots of room, and a serious sleeper
Or, you could do this...
