Author Topic: Aluminum Radiators & Electric Fans  (Read 18787 times)
garyv
« on: October 19, 2013, 09:37:13 AM »
Doing some major upgrades to my 66 Fairlane and one of the things I want to do is go to an aluminum radiator and electric fan or fans.
Have done some research on here and after looking at everything Summit Racing and others have to offer I have to admit it gets confusing.
There are lot of radiators out there. Crites restoration has one that looks nice. There are fans galore with all kinds of CFM claims.
Car is going to have a 427 Tunnel Port, mostly street driven,  so I am going to need to be able to keep it cool. I was thinking a ? Summit aluminum radiator and a set of their high output 12" puller fans that are supposed to move 2600 cfm.
Appreciate any thoughts or recommendations.
Thanks
garyv
Re: Aluminum Radiators & Electric Fans
« Reply #1 on: October 19, 2013, 10:21:26 AM »
On the radiators, I have used the cheap Summit brand with good results on cars up to 700 HP.  They have two rows of 1" cores, and that seems to work pretty well.  When I tried that setup in my Mach 1 with the supercharged engine, though, it was not sufficient, and I ended up with a custom radiator from C&R Radiator with 1.25" cores.  Most recently, with the higher HP naturally aspirated engine in my Mach 1, I picked a Griffin radiator, also with two 1.25" cores.  I only have limited street miles on that one, but so far no problems.
On the electric fans, cfm ratings from most of the manufacturers mean nothing.  You have to specify a pressure drop along with a cfm number in order to get a meaningful result.  This is just like head flow numbers; if you have 300 cfm from a flow bench it is typically done with a 28" pressure drop, which means there is higher pressure above the port than below it.  If you increased the pressure drop, your cfm numbers will increase, rendering them useless from a comparison standpoint.  In the electric fan world, pressure is higher on the outlet side of the fan, because the fan is sitting up against the radiator.  Most of the electric fan manufacturers just give a cfm rating with no pressure drop, and as soon as you put the radiator next to the fan the cfm will drop dramatically.  Also, some fan designs will drop much less than others.  So, with the "free air" cfm rating given by most manufacturers, you really can't get a comparative cooling number.
Spal is the only company I know that offers cfm vs. pressure drop ratings.  And Spal fans are far away the best on the market, IMO.  You can buy from them direct at spalusa.com.
« Last Edit: October 19, 2013, 01:05:14 PM by jayb »
« Reply #2 on: October 19, 2013, 10:31:46 AM »
I will add that you really need to spend more money on an alum fan setup than you would think, especially with a shock tower car.
The air not only has to enter, but needs to find a way out, and with a big FE tower-to-tower, it can be tough.
For true street cars, I have all but given up on electrics in a shock tower Ford.  To me, on the street, the gain is minimal compared to the ease in stable tuning due to underhood temp management and drvability with an engine driven fan.  Racing, certainly a different story, and the ability to shut down an alternator at WOT should gain some power and still be able to remain cool
« Reply #3 on: October 19, 2013, 10:44:47 AM »
I've done a full custom install in a 67 Fairlane and used the Summit kit.
One issue with the Northern rad from Summit is the lower pipe is at a angle pointing up and to the pump.  :P
Must be some kind of chev thing.?
There was cutting and welding on my custom job, but I never was one for shying away from cutting. ::)
« Reply #4 on: October 19, 2013, 11:21:49 AM »
The upward pointing lower hose barb is identical to my cheapie universal fit Griffin aluminum radiator on a '70 Mach 1, all be it with a 351W. Before I bought it, a few on the old Forum said it would be fine....and it is.
I don't think it's a Chevy deal though. Methinks it a circle track function as I've never seen any era of any GM radiator with such an unusual twist/bend.
Think I paid under $200 (like $190 w/o shipping) from Summit although that was some years ago. Had to slightly bend my OEM Ford top radiator hold down bracket to get a good fit. Still, the direct fit Griffin was IIRC about $300 at the time and the one I got works just as well.
I'm also leery of electric fans. Me, I'd run a thermal clutch fan ala' the OEM setup and not worry about a toasted engine.
« Last Edit: October 19, 2013, 11:24:46 AM by machoneman »
« Reply #5 on: October 19, 2013, 12:25:19 PM »
Virtually all current cars use electric fans. Some years ago, I went from the water pump mounted fan that was in my '64 F-100/390 PI combo to an aftermarket electric fan. I bought a style that has a sort-of 'shroud' connecting the ends of the fan blades. It's worked flawlessly ever since but I DO have a relatively open engine compartment.
I'm told that late model electric fans from such as a Taurus can be easily 'bone-yarded' and pressed into service. You'll find that they come as a unit in which the fan assembly is housed in a shroud that also serves as the mount. They not only work good, they look good too!
garyv
« Reply #6 on: October 19, 2013, 01:39:38 PM »
I have read where guys are using the Taurus and Lincoln fans with good results..
Everything now has electric fans and they have a lot less room under the hood than my Fairlane.
I would think with the right radiator and fan it should work.
I don't like the thoughts of running a clutch fan at over 6000 RPM
garyv
« Last Edit: October 19, 2013, 01:41:55 PM by garyv »
« Reply #7 on: October 19, 2013, 02:26:07 PM »
You have my personal guarantee that a good aluminum radiator and electric fan setup will give you no trouble on the street.  Been doing it for years...
garyv
« Reply #8 on: October 19, 2013, 02:51:28 PM »
Jay the radiator I have now is just around 22 " wide and doesn't look like I can go with a 25" one.
The opening in the core support really doesn't allow for anything larger.
Summit has their street strip radiators then they have a 24 inch wide triple pass.
What you think?
Thanks
gary
« Reply #9 on: October 19, 2013, 03:16:51 PM »
I looked at those triple pass radiators when I was shopping for my Griffin; don't see why they wouldn't work.  I've never used a dual pass or triple pass radiator, though, so I can't offer any real world experience.
On my Mach 1 I trimmed the opening in the core support, and also the front frame rails, to fit the 31" wide (26" core) radiators that I've used in that car.  Not a big deal to do that, but I can understand if you don't want to cut anything...
« Reply #10 on: October 19, 2013, 03:47:14 PM »
I am the last guy to argue with either of you, but there is a big "it depends" there.  As a guy who "gets" to move every 3-6 years, I have learned there is a HUGE difference in cooling a car in one climate versus another.  I couldn't even fathom requiring a shroud growing up in Western Mass, cooling issues were non existent,  but in Las Vegas, I learned quickly that it takes a TON of airflow to cool a motor when the ambient air is over 120 and a the surface temps of the road can be over 150 degrees.  It's all about volume at that point
I'll also add that my 489, with the air conditioning at idle, would need a heck of a setup to keep adequate air flowing with the A/C, PS, and all the brackets in the way, not to mention the condenser itself.  In my case, I actually decided to put two dedicated electric fans on the a/c, then space it forward so the engine driven fan would suck around it.  WAY overkill here in Nebraska, but it was a nice design for Las Vegas.
Not to say that we couldnt run electric fans in the desert, but it certainly takes more thinking, and even then, on the hottest of days, my buddy's Rat Chevy stayed home, despite more radiator and a nice pair of Spals
Additionally,  I do agree new cars use electric fans as a rule, but note that the engine driven fans ar still used, now even modified for full electric lockup regularly on trucks.  I'd be hard pressed to compare a 500 hp FE with a tight engine compartment to a 250 hp car with a big open area in front of the engine for air to flow, but I could see comparing it to a V10 Ford or Dodge.  Neither comparisons are identical, but I guess my point is, you need real good stuff if you want it to do what a factory build will do with a 500+ hp FE
Now I will say I agree completely with Jay that if you have a good fan and radiator setup.  It'll run cool, but it needs to be good, and needs to be well thought out if you are anywhere south of Kansas.
Good big fans like the Lincoln and many other large fans will hit the water pump if you run a stock style belt setup, the dual fan setups for the most part don't push a lot of air for a common sized radiator.  However ultimately if you have enough airflow, the car doesn't care what kind of fan it is, as long as the airflow is there
I have long wanted to move my radiator forward, run a  big electric fan, and even thought of sending the air up through the hood like a GT40 :)  However, with the big alum radiator and an aftermarket fixed fan, it runs cool, and I am not afraid to spin it to 6500, so in my normal fashion, I wont take it apart LOL
« Reply #11 on: October 19, 2013, 05:01:58 PM »
Good point about the locale Ross, and also about the accessories like A/C and power steering.  I've had to run my cars down south, during Drag Week, and never had a problem, but there weren't too many traffic jams we had to deal with, and I don't have AC.  The desert and ambient temperature over 110 with a fully optioned car might be a whole different ballgame.
Just can't believe a big pair of Spals wouldn't be up to the airflow requirements, though.  The pair I have on my Mach 1 just move a TON of air...
garyv
« Reply #12 on: October 19, 2013, 10:00:11 PM »
I don't mind opening up the core support some if needed to use a larger radiator.
That sounds like a good suggestion. I'll have to do some measuring.
I'm not running AC so I don't have to worry about that added heat. I'm not in the desert either but
here in WV it gets plenty hot in the summer when the humidity climbs up there.
I have ram air type hood so hopefully that will help get some of the heat out also.
I really appreciate all the input.
gary
fastback 427
« Reply #13 on: October 19, 2013, 11:05:40 PM »
Hey Gary v, I had heating issues with my 67 fairlane overheating as well. Driving or racing it would hit 220. After a dozen combinations what we did was a summit triple pass radiator,cut lower hose fitting and straightened it for hose fittment, run Milodon 160 high flow stat. Then made custom shroud from heavy gauge aluminum with aluminum ring to mount ford Taurus electric fan, used two position switch since fans have low and high. Also used 130 amp wind star alternator. Really helps with fan speed over the 60 amp original. Temp now 160 to 185 Max.also did this same setup on 351 c that ran 220+ and now runs 170 on low fan speed. I can try to post pics if someone is interested.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
mlcraven
« Reply #14 on: October 19, 2013, 11:42:12 PM »
It is my observation that when electric fan set-ups DON'T work satisfactorily, regardless of the brand of fan, the problem can frequently be traced to a poor shroud arrangement.
I went through no end of grief with my (ahem, cough, cough) stroker small-block El Camino.  In the interest of cool factor and weight saving replaced a perfectly serviceable copper-brass rad and engine fan set-up with a Griffin alum rad and electric fan installed with the plastic ties that run between the rad fins.  The result was miserable, engine temp consistently 20-25F higher with the fan as a puller, and 30F+ or worse in pusher configuration.  Finally had an alum shroud fabbed up that covers the complete surface area of the rad and sets the fan 2-in back.  Presto, temp dropped back to steady 180F even on the hottest days.
I would humbly submit that the pic Howie posted above of his Fairlane cooling system illustrates how things should be done, fully sealed with the fan set back from the face of the rad.
I'm sticking with the stock rad and engine-driven clutch fan on the Cyclone, which will work just fine with a mildly warmed-over 390 carrying 2 extra quarts of oil in a deep Milodon pan (and will never likely see beyond 5000 rpm).
Michael
