Author Topic: 2x4 fuel log  (Read 267 times)
2x4 fuel log
« on: November 19, 2026, 10:34:45 PM »
How much power can the 2x4 fuel log support before it fuel starves ?
I do run an electric pump and 1/2 inch line from tank to fuel distribution block and 3/8 to the log
Re: 2x4 fuel log
« Reply #1 on: November 20, 2026, 02:00:28 PM »
I can’t imagine the fuel log being the cork in the system.
Be interested to see any data showing where/when that happens.
MRHP
Re: 2x4 fuel log
« Reply #2 on: November 20, 2026, 02:08:34 PM »
I'm about to try it on a 740hp Hi-Riser. Running -12 from tank to an Aeromotive 4 port dead head regulator...(I'm only using one of the output ports  -6 into the back of the stock style fuel log). This is for street application only. I don't think there will be enough room on the street to stay full throttle for more than a few seconds. If it goes to the track, will be running a -6 to each carb out of the regulator. Fuel pump is Aeromotive 400gpm.
hbstang
Re: 2x4 fuel log
« Reply #3 on: November 20, 2026, 05:19:15 PM »
thats a huge fuel pump at 400 gpm.160 is enough for 900 na.but you should be ok.does that pump have a bypass?and what pressure is the pump set up for?you may have to much pressure with a dead head regulator.
MRHP
Re: 2x4 fuel log
« Reply #4 on: November 21, 2026, 10:03:38 AM »
Just double checked, it's an Aeromotie A2000 and their website says it's good for up to 350gpm (my bad).
Yes, the pump has a bypass, and I have it set at about 10-12psi. Is it overkill, yes...lol
I was also skeptical of the dead head, but it seems to be the way everyone is going these days and I set it at 3psi to start with so as not to sink the floats and hydraulic a cylinder.
Plus, I have the same system on a big inch Windsor in a drag car and it works really well.
A little back story here. Back in the mid 90's early 2K's I had a T-Bolt clone with a de stroked 396ci HR on Alcohol. Fought fuel starvation for a whole season and learned alot about fuel volume vs fuel pressure. Hence the overkill on this fuel system.
