FE Technical Forum
Drive shaft yoke
Topic: Drive shaft yoke (Read 240 times)
bsprowl
Sr. Member
Drive shaft yoke
November 13, 2026, 02:31:38 PM »
My engine is a BBM 482. I bought a Tremec TKX which should handle that but I did not realize that it needed a 500 mile break in before racing. I don't want to use my race motor to break in the transmission.
I have a 390 (about 475 HP) engine that I will use for break in. I need a Drive shaft for the TKX about 36 inches long. Is a 3" aluminum shaft OK or should I go to to 3.5".
The 390 was planned to be an alternate engine for my son in the car as he's never raced. The 390 will be using a Big-in, Big Out Toploader and it will need a 37-1/4" driveshaft when he's in the car.
Is it possible to use the same drive shaft for both combinations; specifically is there a yoke that is splined completely to allow it to be used with the lower HP 390? I've got a For yoke that is 6-5/8" long but there are no splines in the first 2-1/2". The Ford yoke slides all the way in on both transmissions and rotates fine.
Thanks in advance.
Re: Drive shaft yoke
Reply #1 on:
November 13, 2026, 06:20:25 PM »
Even though some slip yokes are pretty long, you don`t want a bunch of that hanging out the tailhousing. I wouldn`t want 2" hanging out, very likely to cause a vibration, at best. Especially when even the 390 sounds pretty healthy.
FE Technical Forum
Drive shaft yoke
