Author Topic: Water won't drain  (Read 866 times)
Boiler Ben
Water won't drain
« on: November 12, 2026, 03:26:26 PM »
I just got back from dyno testing my engine.  It all went great until we went to drain the water from the block.  Pulled water drains from both sides and no water came out.  Tried poking around a little and still nothing.  Since it was straight water and getting colder at night, I want to drain this somehow.  The shop suggested either carefully running a drill bit in to clear out whatever junk has collected, or try to remove a freeze plug.  They said the freeze plugs can be difficult to get out.  One of them is weeping water out very slightly, no drips, just a little stain.  Any suggestions?
mygasser
Re: Water won't drain
« Reply #1 on: November 12, 2026, 05:00:10 PM »
if you already have one weepy core plug you know what to do. buy a set and replace them all. they rust from the inside out so you won't know until one strands you at the side of the road. it's cheap insurance and you can have a poke around in the water jacket too while they're all out. also a drill bit in a pair of vice grips will be able to poke through the crap set where the block drains are. once you've cleared whatever you can run a hose through until it runs clear.
neil.
« Reply #2 on: November 13, 2026, 12:14:45 AM »
Pretty common for the block drain holes to get plugged up with crud. I have never had one that wouldn`t start draining after sticking a screwdriver in the hole and giving it a light tap to break thru the "crust"
Unless of course somebody has filled part of the water jackets with "Hard Block" filler, or something similar. But try poking a screwdriver into the holes first.
428kidd
« Reply #3 on: November 13, 2026, 08:19:03 AM »
Agree with both posts here. Don't drill any thing , take a screw driver and lightly tap it to knock crude loose . Again unless it has been hard blocked half way. If you already have a leaking plug go ahead and pull them. Makes sure when you go back your using the correct size and I lightly coat the outer edge of mine with GM grey rtv and wipe the excess off. If your just doing it for storage and dont want to pull the plugs add straight antifreeze down each side of the water pump holes.
Boiler Ben
« Reply #4 on: November 13, 2026, 11:50:19 AM »
Under the plug it's white, hard, cement like.  So I guess it's been filled.  I will try to get a freeze plug out next.
Boiler Ben
« Reply #5 on: November 13, 2026, 02:51:01 PM »
And I just pulled out all the plugs to get all the water out.  The filler material comes up to the bottom of the freeze plugs.
mygasser
« Reply #6 on: November 13, 2026, 03:02:46 PM »
you could solder a fitting to one of the new core plugs and screw a drain tap into it once installed.
neil.
« Reply #7 on: November 13, 2026, 07:21:09 PM »
Pour a little anti freeze in the block. After you fix the freeze plug. Easy easy.
